Honda S2000 Honda S2000
how much do you think these would cost to fix?
Old Sep 20, 2007 | 09:29 AM
ajwiant's Avatar
Default how much do you think these would cost to fix?
#1:
and
#2:
thats all the damage I can see on that car. I dont know if it was wrecked before, but its being auctioned near my house. the rear wheel looks messed up though.
what do you think?
Old Sep 20, 2007 | 10:05 AM
m R g S r's Avatar
Default Re: how much do you think these would cost to fix? (ajwiant)
deff. go for the second one over the first....
probably an LCA on the rear wheel, no biggie.....sucks that the side skirt is part of the car thou, so it needs to be cut out and a new one welded in to be fixed properly.....i guess you could pull the dents and plastic it, but unless you have someone who is real good with plastic, then i wouldn't reccommend it.
Good luck
I highly doubt it, but the rear subframe could be bent.....so get it checked out first...either way I'm sure you can pick up a used one from a salvage yard with an S2k with front end damage (if the subframe is bent)
Old Sep 20, 2007 | 10:12 AM
Curiouz_G's Avatar
make sure which has subframe damage. any s2000 with it wont feel the same no matter how well its been repaired.
Old Sep 20, 2007 | 10:13 AM
blkturbos2k's Avatar
I would say $5k for the white one
1, 500 each headlamp
2, 1000 for frt and rear bump with paint
3, 1000 for the 2 fenders with paint
4, 500 for frt and rear bump reif
5, 300 for taillamp
6,the other 1700 is for all the body work you will need to get done to the 1/4 and the front of the car
Dont buy the silver one
Old Sep 20, 2007 | 11:49 AM
Black S2K's Avatar
yo take it from me i bought a salvaged s2k and fixed it. Go with the white one all it is is boddy damege and its easy to fix everyhting can be replaced exept you dont have to replace the rear quater it could prolly be pulled out and bondoed and it would be fine. anyways mines was 47hundred and after i fixed it it came out to 93hundred with all the paperwork and tags. heres my pix
Old Sep 20, 2007 | 12:17 PM
WHO YOU's Avatar
Default Re: (Black S2K)
How do you KNOW that its only body dmg?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black S2K &raquo;</TD></TR><TR><TD CLASS="quote">yo take it from me i bought a salvaged s2k and fixed it. Go with the white one all it is is boddy damege and its easy to fix .....
Old Sep 20, 2007 | 01:05 PM
al4t1gbundy's Avatar
Default Re: (WHO YOU)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WHO YOU &raquo;</TD></TR><TR><TD CLASS="quote">How do you KNOW that its only body dmg?
you cant really know unless you lift the car up and inspect the frame etc.
btw im assuming the airbags are still good? And take off that spoiler and ship em to me !!
Old Sep 20, 2007 | 03:39 PM
LBBP R's Avatar
Default Re: (blkturbos2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkturbos2k &raquo;</TD></TR><TR><TD CLASS="quote">I would say $5k for the white one
5, 300 for taillamp
Dont buy the silver one</TD></TR></TABLE>
agree, i would rather than #1 from #2.. from the pix, all you need to do is replace couple parts here and there. all tho $5k seems too little to get it repaired. i would say.. $8-10k
from the pix #2, needs lot of work on the side and it looks like the floor sub-frame might be bent....
Old Sep 20, 2007 | 04:30 PM
SlammedDC2teg's Avatar
Default Re: (LBBP R)
If your looking to get it done right , #1 is going to cost alteast 8k. They wouldnt be in a salvage yard if it was cheap to fix.
Old Sep 20, 2007 | 07:04 PM
ajwiant's Avatar
Default Re: (SlammedDC2teg)
the white one is 3 grand. if i had the cash to buy it i'd be real tempted. im tempted anyway.
Old Sep 21, 2007 | 11:14 AM
lonestar55's Avatar
Default Re: (ajwiant)
id go with the white one also. you never know the silver one might be shorter on that side due to that bend, and plus repairing that one would be a lot more work
Old Sep 22, 2007 | 12:23 AM
iHATEspeedbumps.'s Avatar
Default Re: (lonestar55)
that second looks to be my friends old s2k she drove off a mountain a month ago. by any chance is that silverstone one in the bay area?
Old Sep 22, 2007 | 05:23 AM
Francesco's Avatar
Default Re: (iHATEspeedbumps.)
as long as theirs no subframe damage your good to go.
#1 is actually an easier fix since its all bolt ons and paint, but its going to be more money.
#2 is harder to fix because you can't order a new rocker pannel, you have to hammer that one out.
Old Sep 22, 2007 | 08:00 AM
Mr. EK9's Avatar
Default Re: (Francesco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">as long as theirs no subframe damage your good to go.
#2 is harder to fix because you can't order a new rocker pannel, you have to hammer that one out.</TD></TR></TABLE>
ill agree except the second one would be more to repair because it would take alot more time to do the body work and im willing to bet there is hidden damage under there....
Old Sep 22, 2007 | 08:43 AM
Black S2K's Avatar
RE: Who You
Quote, originally posted by Black S2K »
Cause Im the **** thats how I know all the cars I have owned were salvaged cars that I rebuilt so I have a lil experience in that department. Unless the #1 car went flying into a ditch/ curbs and fucked up the suspension then theres more then just body damage. But all the tires look straight the dude prolly spun out and hit a pole or gardrail.
Seriousely for 3k get it you wont regret it esp if you can do most of the work yourself.
Old Sep 22, 2007 | 10:44 AM
Mr. EK9's Avatar
honestly for what it costs these days for a used s2k... its almost just as cheap to buy a non wrecked one that buying a totaled one and fixing it up...
3k for wrecked s2k+8-10k in damage=$12ishk for a salvage title s2k
12ishk for a 00' s2k with a clean title....
i know what id go with...
Old Sep 22, 2007 | 12:24 PM
kabaroo's Avatar
Default Re: (Mr. EK9)
where is this white one?? For 3k i would give it a whirl.. If you do all your own work i could see fixing it for $3000
Old Sep 22, 2007 | 01:27 PM
bky's Avatar
bky
I agree that for the cost of repair, it's better to buy a used one. Remember that even if you fix it as good as new, you still have a salvage title and probably won't get your money back out of it like a clean used car.
Parting them out would be more profitable. I see two F20C donors for an AE86 or Caterham. :-)
Jahz
Paint and Body
16
Jul 20, 2013 09:01 AM
Calesta
Honda Ruckus and Scooters
13
Sep 29, 2010 07:26 PM
MADEinJAPAN
Feb 6, 2004 02:40 PM
t0p_sh0tta
32
Feb 10, 2003 08:37 AM
slowassR
Aug 12, 2002 07:17 PM
