Quick question.. I need to know the correct tire pressure.
Old Sep 20, 2007 | 09:05 AM
kaluwa3's Avatar
Default Quick question.. I need to know the correct tire pressure.
Old Sep 20, 2007 | 09:09 AM
crazyguy's Avatar
Default Re: Quick question.. I need to know the correct tire pressure. (kaluwa3)
36 psi is what i have on my 2000 si wheels with 195 / 50 ZR / 15 tires...
Old Sep 20, 2007 | 09:19 AM
kaluwa3's Avatar
Default Re: Quick question.. I need to know the correct tire pressure. (crazyguy)
So would it be the same for my 205/50/15's?
Old Sep 20, 2007 | 07:34 PM
doood's Avatar
been there done that
recommended tire pressure should be on a sticker either on the door jamb or in the glove box. or in the owners manual maybe.
Old Sep 20, 2007 | 07:35 PM
forcefedferio's Avatar
Default Re: Quick question.. I need to know the correct tire pressure. (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaluwa3 &raquo;</TD></TR><TR><TD CLASS="quote">I need to know what the correct tire pressure for a 2000 civic si would be. </TD></TR></TABLE>
enough go with 32-35 psi.
Old Sep 20, 2007 | 07:38 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">recommended tire pressure should be on a sticker either on the door jamb or in the glove box. or in the owners manual maybe.</TD></TR></TABLE>
And it should be noted that these are a good general guideline, but you may want to make your own adjustments. I normally find the manufacturer's recommendations a bit low for my usage.
RCautoworks's Avatar
Old Sep 20, 2007 | 07:40 PM
doood's Avatar
Default Re: Quick question.. I need to know the correct tire pressure. (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
And it should be noted that these are a good general guideline, but you may want to make your own adjustments. I normally find the manufacturer's recommendations a bit low for my usage. </TD></TR></TABLE>
indeed. on my sticker it calls for 30psi cold. i usually put in 35psi.
Old Sep 20, 2007 | 10:11 PM
RiceKillinSI's Avatar
It can also depend on the tires you have. High performace class tires tend to need a higher tire pressure than a all season tire. I run a high performance summer tire and i run 45psi, but they have a max of 51psi. Anything less feels like crap. Just make sure you do not inflate your tires higher that the max psi rating on the side of the tire!!.
bonSI
Jul 12, 2008 01:38 PM
Proto05
Sep 15, 2007 10:34 AM
pnoi_01dc2r
May 28, 2007 07:24 AM
jonzel
Dec 7, 2006 10:20 AM
ExiledinIN
Apr 20, 2005 07:24 AM
