Skunk Manifold and 70mm TB..Which ECU??
Old Sep 20, 2007 | 08:29 AM
Halo's Avatar
Default Skunk Manifold and 70mm TB..Which ECU??
Recently got my SK2 manifold port matched to a 70mm BDL TB..Since I will be running single runners what ecu do you recommend? Mods so far are
Camp header
SK2 mani
BDL tb
CAI
2.5 exhaust
Car is 98 base
Old Sep 20, 2007 | 08:53 AM
PrecisionH23a's Avatar
Default Re: Skunk Manifold and 70mm TB..Which ECU?? (Halo)
I would go with a hondata system. The s300 is the best hands down
Old Sep 20, 2007 | 10:15 AM
98vtec's Avatar
moderator emeritus
Default Re: Skunk Manifold and 70mm TB..Which ECU?? (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">I would go with a hondata system. The s300 is the best hands down </TD></TR></TABLE>
ecu honky
i'd chose the p28. Cheap and abundant. You can also get p06's that are converted to p28 boards for just as cheap as they are very abundant and the conversion is very simple.
Old Sep 20, 2007 | 10:59 AM
Default Re: Skunk Manifold and 70mm TB..Which ECU?? (98vtec)
Yea but he can't throw a stock p28 and have it run worth a damn
If you want to keep your knock sensor run the p72 ecu.
Old Sep 20, 2007 | 11:24 AM
98vtec's Avatar
moderator emeritus
yea, just dont expect to get any knock readings that are of any value , but it will keep the knock CEL away.
pacey
19
Nov 10, 2007 06:56 PM
JDMxNguyeN
Aug 26, 2006 11:04 PM
DA6mike2
Jul 26, 2006 02:01 PM
Maddox
Feb 19, 2005 04:34 AM
Nextelbuddy
Nov 20, 2003 07:53 PM
