Which Cams is the best??
Old Sep 19, 2007 | 10:59 PM
SOL-Hatchback's Avatar
Default Which Cams is the best??
ok guys.. i've been thinking about upgrading my cams to aftermarket ones but not sure which one is the best to go with.
i have an jdm gsr motor with H/I/E and an skunk2 intake manifold. i was thinking about going with the Skunk2 Pro-Series stage 1 cams or either the Buddy Club Spec3 cams, which one would make more power?
also wanted to know, anything i should do to bump the compression up safely? i was thinking changing the valves and head gasket, what kind of head gasket should i get to bump the compression up? or should i just change ctr pistons since they're really cheap, but i have heard ppl say that ctr pistons bumps up a LOT like 12:5 or even 13:1, but a shop locally have told me that if i was to install ctr pistons for my gsr, the compression will only go up to about 11:5, that true?? please help me out guys!
Old Sep 19, 2007 | 11:25 PM
Lazychynksta's Avatar
Default Re: Which Cams is the best?? (SOL-Hatchback)
SKUNK 2 stage 1
Old Sep 20, 2007 | 12:48 AM
quicksilver1689's Avatar
i ♥ snails
i think b16 pistons would be the best best, b16b aka ctr pistons in a gsr yield a pretty high c/r that i dont believe is very street able without proper octane or pulling butloads of timing which would defeat the purpose.
Old Sep 20, 2007 | 05:05 AM
Chillinit's Avatar
Your shop is mis-informed. If you install CTR pistons, you compression will be much higher then 11.5:1. I think it would be around 13.5:1 but don't quote me on that. Anyway, as for your cam selection, the first question you have to ask yourself is what is...your intended use? Street strictly? 1/4 mile? Circuit?
My personal choice would be BC3+. They will give you more mid-range power and overall more power under the curve. Not to mention, the throttle response on those cams are unmatched. Even the Bc4's cannot compare in that aspect.
Old Sep 20, 2007 | 08:46 AM
Cow's Avatar
Cow
CTR pistons, assuming stock headgasket and non-milled head will yield a compression ratio of 12.0:1. You would probably be better off with something a little less aggressive. USDM B16 pistons or JDM ITR pistons will be around 11.4:1.
You should probably bookmark this site: http://www.c-speedracing.com/h...c.php
Then again, why go there when we can just make up numbers and throw them out? That seems to be what most people go with.
Old Sep 20, 2007 | 10:03 AM
b19coupe's Avatar
Pro 1's or Toda C's are good for mild 1.8s.
Old Sep 20, 2007 | 10:06 AM
autox228's Avatar
Default Re: Which Cams is the best?? (b19coupe)
pro1 with a good tune..
Old Sep 21, 2007 | 04:28 PM
Default Re: Which Cams is the best?? (autox228)
hmmm ok i'll probably be going with the skunk2 pro stage1 cams with skunk2 valve springs and retainers. what kind of head gasket is good to bump up the compression a bit? and also i'm thinking about getting the skunk2 high compression valves to bump the compression a bit too.
what if i don't change any pistons, will i still make pretty good power with the skunk2 cams?
Old Sep 21, 2007 | 04:57 PM
autox228's Avatar
i ran the skunk pro1 cams, skunk valvetrain, skunk IM, and rmf header on my jdm gsr in my hatch.
Old Sep 21, 2007 | 07:38 PM
yeah pretty much the same as my hatch, how much power did u make out of it? had to get dyno tuned or just street tuned?
95cxGSR
Jun 3, 2004 09:54 AM
Driven
14
Apr 4, 2004 10:58 PM
JDM4DR.GSR
Mar 20, 2004 06:50 PM
tour de france turbo
Nov 19, 2003 06:04 AM
devoxtekxhb
Oct 4, 2002 06:22 AM
