Installed Accord Timing Belt. Now no spark.
Old Sep 19, 2007 | 10:40 PM
PhilipK's Avatar
Default Installed Accord Timing Belt. Now no spark.
I just did a timing belt job for a friend on a 1993 Honda Accord SE and now there is no spark, car ran fine before it came in. I installed it perfect, everything was lined up and it is not 180 off. My question is what could have gone wrong. All the ignition componets are 6 months old and are Honda parts; dissy, cap, rotor, coil, ignitor, main relay, wires, and plugs. I have also checked everything with a multimeter and they check out. There is power to the coil, but no spark from the coil wire. Is there anything that I could have done to the timing belt to kill the spark. I am stumped.
Old Sep 21, 2007 | 12:36 PM
seeodywhy's Avatar
Default Re: Installed Accord Timing Belt. Now no spark. (PhilipK)
I switched an engine in a 93 ex and had the same problem for days before i figured it out. Did you use a manual for some general instructions. Try to rotate the wire on the dist cap one position counter clockwise because many manuals asume that that cap is held with the long side held at parallel with the ground. However while it is on the car it is turned up at a 30 degree angle or so
Old Sep 21, 2007 | 12:43 PM
seeodywhy's Avatar
Default Re: Installed Accord Timing Belt. Now no spark. (seeodywhy)
Also check the Ignition Control Module if you haven't already cuz those things are fragile.
Drigley
Feb 18, 2012 07:49 AM
lsvtek
May 11, 2008 11:06 PM
vtec92accord
Mar 13, 2007 06:26 PM
snakedoctor
Feb 14, 2006 07:47 AM
dblack
Apr 14, 2004 05:53 AM
