Best Piston for my Setup? JDM ITR, CTR, Standard Bore, .25, .50?
Old Sep 19, 2007 | 09:05 PM
odogg726's Avatar
Default Best Piston for my Setup? JDM ITR, CTR, Standard Bore, .25, .50?
Like the title says guys, I'm trying to decide between going with the JDM ITR standard bore pistons I already have, or should I go with:
CTR Standard Bore
JDM CTR or ITR .25 over
JDM CTR or ITR .50 over
Setup looks like this:
68mm Skunk2 Throttle Body
Skunk2 Intake Manifold (GSR)
P&P GSR Head
Skunk2 Springs and Retainers
Skunk2 Pro 1 Cams (Not Stage 1, Pro 1's, sorry, haha)
Skunk2 Pro Series Cam Gears
JDM 98+ Spec Type-R Tranny w/4.7 Final Drive.
Any help would be greatly appreciated, especially cuz if I go in to the block to change the pistons, I don't wanna have to go back in there for a while. Pro's and Con's would also be appreciated. Thnx again in advance guys.
Old Sep 19, 2007 | 09:15 PM
odogg726's Avatar
Default Re: Best Piston for my Setup? JDM ITR, CTR, Standard Bore, .25, .50? (odogg726)
I guess I'll place the first vote, since these are the ones I already have now.
JDM ITR Standard Bore Pistons.
Old Sep 19, 2007 | 09:46 PM
saver's Avatar
how aggressive would you want to go.
Old Sep 19, 2007 | 09:52 PM
odogg726's Avatar
Default Re: Best Piston for my Setup? JDM ITR, CTR, Standard Bore, .25, .50? (saver)
about as agressive as i can get away with, while still being streetable...
Old Sep 19, 2007 | 11:04 PM
odogg726's Avatar
also, about as aggressive as the setup i posted up on top.
Old Sep 20, 2007 | 04:42 AM
odogg726's Avatar
bump it...
Old Sep 20, 2007 | 08:38 AM
iH8RICERZ's Avatar
Sounds almost like my set up I'm working on.....except I'll be using different brand parts. As for the pistons that are in the block already, they're ctr .25 oversized pistons. After doing a lot of research, people have produced really good gains, BUT everyone has emphasized that tuning the car was a huge factor into making sure this set up runs correctly. People tend to go towards jdm itr std or .25 oversized just because you have more room for tuning.
Old Sep 20, 2007 | 09:05 AM
odogg726's Avatar
Default Re: Best Piston for my Setup? JDM ITR, CTR, Standard Bore, .25, .50? (iH8RICERZ)
ok, cool. Thnx for the info, i appreciate it. MAybe I'll stick to these standard JDM ITR's for now.
Old Sep 20, 2007 | 11:10 AM
odogg726's Avatar
anyone else?
Old Sep 20, 2007 | 06:49 PM
odogg726's Avatar
so that's it, huh guys?
Old Sep 20, 2007 | 07:21 PM
doood's Avatar
been there done that
standard p30's
more compression than itr's, less than pct's.
Old Sep 20, 2007 | 08:18 PM
-Darren-'s Avatar
Default Re: Best Piston for my Setup? JDM ITR, CTR, Standard Bore, .25, .50? (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">standard p30's
more compression than itr's, less than pct's.</TD></TR></TABLE>
so true, also i would get oversized pistons. its always good to go oversize on a rebuild, to get a fresh round bore.
also .25 over is good enough.
Old Sep 22, 2007 | 01:11 AM
odogg726's Avatar
Default Re: Best Piston for my Setup? JDM ITR, CTR, Standard Bore, .25, .50? (-Darren-)
how do you guys think the setup i listed above would workif I went with the .25 over JDM ITR pistons? Kinda what I'm leaning towards right now.
Old Sep 22, 2007 | 07:33 AM
-Darren-'s Avatar
it work as good as it was built and tune.
what do you mean exactly?? also you should check the all motor forum since they discuss setups similar to that all the time.
Old Oct 4, 2007 | 09:03 AM
odogg726's Avatar
Default Re: (-Darren-)
sup guys? Decided to go with some JDM ITR .25 over, I figured the block's probably gonna need to be resurfaced, so might as well bore it out a quarter and play it safe. Thnx for the input guys.
Old Oct 4, 2007 | 09:17 AM
evildc2's Avatar
Default Re: (odogg726)
stick arround with itr 0.5 they have bigger valve pockets than the rest , p30 is a good choice also, since your running gsr heads your compression is going to be high" watch out"i wouldnt use ctr unless your using this set for off road with racing fuel,any how your set up sounds sweet dude good luck
Old Oct 5, 2007 | 06:00 PM
odogg726's Avatar
Default Re: (evildc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evildc2 &raquo;</TD></TR><TR><TD CLASS="quote">stick arround with itr 0.5 they have bigger valve pockets than the rest , p30 is a good choice also, since your running gsr heads your compression is going to be high" watch out"i wouldnt use ctr unless your using this set for off road with racing fuel,any how your set up sounds sweet dude good luck </TD></TR></TABLE>
Thnx man, I appreciate it.
Old Oct 5, 2007 | 06:32 PM
myfirstdc2's Avatar
why not just do 82mm bore p30 or p73? if u gonna spend money on a quick build, why not get a good bang for your buck? with a good tune u can pretty much run a high compression and get away with a dd, even with pct's. tune is mandatory. to me if u spend any money make it worth your while. as long as it's within your budget why not take it as far as it can go. honestly i would do a p30 ( higher comp than p73) 82mil bore and a bad *** tune and you set. of course it all depends on your head setup but at least your block is set to go. good power good budget and good power thats just my 2 cents
Eluzion
May 10, 2004 06:45 PM
Blazin Si
21
Jan 14, 2004 10:47 AM
E-spec Tuner
Dec 2, 2003 10:59 PM
QWKPHKR
Nov 19, 2002 08:42 AM
