installing aeromotive A1000-6 FPR
i am going to be installing an aeromotive a1000-6 fpr and i have a few questions about the return line outlet. I know it is a -6AN fitting but my question is can i use a -6 AN Male to 7mm Hose Barb fitting for the return outlet to fit on the stock return line....i will eventually be running a -6AN return line all the way through to the tank but that will be in the future
any help would be greatly appreciated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbryde1212 »</TD></TR><TR><TD CLASS="quote">i am going to be installing an aeromotive a1000-6 fpr and i have a few questions about the return line outlet. I know it is a -6AN fitting but my question is can i use a -6 AN Male to 7mm Hose Barb fitting for the return outlet to fit on the stock return line....i will eventually be running a -6AN return line all the way through to the tank but that will be in the future
any help would be greatly appreciated</TD></TR></TABLE>
im not sure if they make a fitting that goes from -6 to that small but if they do i dont see why u couldnt do that it wouldnt be the best but w.e. works for u...
they make that fitting...i saw it on the aeromotive website...i believe it is the same fitting that comes with this regulator http://www.aeromotiveinc.com/p...od=67
