changing lower control arms on my 88'crx
Old Jun 17, 2002 | 02:27 PM
uneekcrx's Avatar
Default changing lower control arms on my 88'crx
i need new rear shocks on my 88' crx and the market for good adjustable shocks for an 88 is terrible so i want to change the rear lca's to put 89-91 shocks on it....so my question is what lower control arms can i use to make it a driect fit....
-oh by the way it's a si
Old Jun 17, 2002 | 03:03 PM
CRXRageD's Avatar
Default Re: changing lower control arms on my 88'crx (uneekcrx)
If you can, find some 89-91 Si LCA's. I have to do the same thing with my 88 CRX. I have the LCA's but I need to replace the bushings before I install them. I have some Koni Sp3&sp4 neuspeed spec'd Yellows with GC coilover adapters. It's a nice setup but I won't be able to attach them until my summer school is over. BTW, you have to get the Si LCA's. The dx and hf do not have the holes for your stock sway bar so if you use the other ones, you will have to go aftermarket like a Suspension technique kit which will run around $200+. HTH
Old Jun 17, 2002 | 03:18 PM
uneekcrx's Avatar
Default Re: changing lower control arms on my 88'crx (CRXRageD)
what about the lca's from the same generation integra? or would they be different?
Old Jun 17, 2002 | 03:20 PM
EL Vap133's Avatar
If you don't want to go through all that trouble, just get the rear shocks for a Type-R, they are same as an 88 CRX. I got Bilsteins on my 88.
Old Jun 17, 2002 | 03:23 PM
uneekcrx's Avatar
Default Re: changing lower control arms on my 88'crx (Vap133)
type-r what...crx?integra?
Old Jun 17, 2002 | 03:39 PM
Trinity's Avatar
hey i will buy your lca's when your done if nothing is wrong with them.
you can buy itr shocks for your car though, direct fit, same rear supension
Old Jun 17, 2002 | 05:09 PM
88 CRX SiR's Avatar
Default Re: changing lower control arms on my 88'crx (Trinity)
That's right. 88 CRX has same rear suspension as ITR. I thought about changing over to full ITR suspension & 5 lug but not sure.
Old Jun 17, 2002 | 05:27 PM
DTAYLOR's Avatar
New User
I have some Tokico struts that fit the 88 crx. They are adjustable. Make me a offer.
[Modified by DTAYLOR, 2:27 AM 6/18/2002]
Old Jun 17, 2002 | 06:50 PM
uneekcrx's Avatar
Default Re: changing lower control arms on my 88'crx (DTAYLOR)
illumina 5-ways..? how many miles on them?
UndergroundTuning
Jul 14, 2009 04:19 PM
Skipper75
14
Apr 21, 2007 12:34 PM
Skipper75
Suspension & Brakes
Apr 20, 2007 07:54 AM
Skipper75
Apr 16, 2007 06:48 AM
uneekcrx
Jun 20, 2002 11:58 AM
