WHAT t- BELT ON A B16A????????
Check out this parts list out
--Honda Motors Online --88-91 SiR B16 full change over kit 5XXXXX JDM SiR
--Rear mount bracket(came with engine) 50827-SK7-020 JDM SiR/ 90-93 Integra
--Y1 LSD tranny Y1 LSD JDM SiR
--Pr3 ecu (OBD 0) 37820-PR3-003 JDM SiR
--Pr3 axles (installed but had to remove hub seals) Hasport reports these are 86-89 Integra Axels w/ 90-93 Integra inner CV joints. (which are longer & stronger) “RAXLES†1 800 257-8192 (FL) will supply axels to fit with hub seals 88-91 Civic/CRX B Series Swap with Y1 or SH3 Intermediate shaft. $329.95 Pair Part# RAXBGEN4Y1
--CV Joint BOOTS (inner & outer that came on SiR axels) Inner = 44315 SK7-J02(Honda PN on boot)Outer = 1402 Sjsumar (the outer boots were replacement glue together type) 86-89 or 90-93 Integra LS (all models fit SiR Axels)Acura PN’s for replacing CV Boot’s ?????Inboard 44315-SM1-A01Outboard 44333-SF1-962Damper weight band 44352-SA2-300
--2 outer cv boot set ??? 44018-ST7-C03 90-91 Integra
--2 inner cv boot set ??? 44017-SK7-A00 90-91 Integra
--Trans Axle Seal(Pass. Side only) 91205-PC9-711 90 Integra
-- Intermediate Shaft Y1 JDM SiR
--Intermediate Shaft Seal (installed new) 91260-SK-013 90 Integra
--Hasport billet mounts (installed) 88-91 Civic/CRX EFB1
--Hasport linkage (installed) 88-91 Civic/CRX EFB1
--Trans. Shift Rod Boot(installed) 24316-PS1-000 90-91 Integra
--Alt. Belt..Auto Zone had 4PK760 belt which was shorter & fit perfectly… Brand Name was.... KellySpringfield #300K4
--(Factory belt # with engine)- 31110-PR3-004 (4PK770) was almost too long
--Dist. rotor Bosch 04277 90-91 Integra
--Dist. Cap Bosch 03376 90-91 Integra
--4 spark plugs NGK 5724 BKR6E-N-11 (I Used ND K20PR-L11 from JDM B16 Manual) 94 Del Sol DOHC Vtec
--Energy Suspension shifter stabilizer kit (installed new) 16.1101G 94 Del Sol DOHC Vtec
--“Energy Suspension†Poly Bushings – Rear Suspension(Installed) Lower Control Arm Set 16-3104 89 Civic
Shock Mount Set 16-8103 89 Civic
Sway Bar Set (not installed) 16-5112 89 Civic
Trailing Arm Bushing 8-304-BL 89 Civic
--Valve cover gasket 12341-PR3-000 94 Del Sol DOHC Vtec
--4 valve cover o-rings 12342-PG6-000 94 Del Sol DOHC Vtec
--8 valve cover grommets 90442-P30-000 94 Del Sol DOHC Vtec
--T-belt (installed new) 14400-PR3-004 94 Del Sol DOHC Vtec
--W-pump (installed new) 19200-P30-003 94 Del Sol DOHC Vtec
--Oil pan gasket (installed new) 11251-P30-004 94 Del Sol DOHC Vtec
-- Fuel filter (installed new) 16010-SH3-505 89 Civic Si
--Exhaust Manifold to Header Gaskets ( 2 Required ) 256-170 94 Del Sol DOHC Vtec
--Intake Gasket (installed new) 17105-P30-004 94 Del Sol DOHC Vtec
--Spark plug wires 32722-P30-000 94 Del Sol DOHC Vtec
--Oil filter 15400-P0H-305 94 Del Sol DOHC Vtec
-- I used Fram PH 3593A 94 Del Sol DOHC Vtec
Used Castrol GTX 10W40 Oil in engine. No real reason for choice
****B16 JDM Manual recommends 10W30 for temps –20 to +90****
Used Val 10W40 in Trans. No reason except avail.
*****B16 Manual recommends SAE 10w30 or 10w40 (full temp range)*****
OR use Homda Manual Transmission Oil.
--distributor bolt 90003-P01-000 94 Del Sol DOHC Vtec
--2 new Brembo brake rotors (installed) 89 Civic Si
--Hawk Performance-- HPS compound front pads (installed) HB218F . 583 89 civic Si
--NAPA Rear Drums (installed new) 440-1551 89 civic Si
--NAPA Rear Shoes (installed new) AE-546 Premium Shoes 89 civic Si
--NAPA Rear Wheel Cyl’s 46375824637581 89 civic Si
--Exhaust Mid pipe –2.5†SSAUTOCHROME 89 Civic Hatch
--High-Flow Cat- 2.5" from SSAUTOCHROME
-- Used Factory B16 Manifold (4-2-1) bolts up to Si Exhaust Perfectly(Current installation) SSAUTOCHROME 2.5†Midpipe (uses factory donut gasket at rear) 89 civic Si Hatchback
--2 cam seals 91213-PR3-004 94 Del Sol DOHC Vtec
-- front Crank seal 91212-PR3-003 94 Del Sol DOHC Vtec
--Main oil seal (rear) 91214-PH1-004 94 Del Sol DOHC Vtec
--Shifter stabilizer washer (A) 54305-SA0-000 94 Del Sol DOHC Vtec
--Shifter stabilizer washer (B) 54304-SK7-000 94 Del Sol DOHC Vtec
--Radiator Cap(installed new) 19045-PM3003 89 Civic Si
--Thermostat w/gasket 19301-P08-305 94 Del Sol DOHC Vtec
--Coolant 50-50 w/disitilled water Prestone Long Life (GM DEX COOL)
--Main Relay 39400-SH3-003 89 Civic Si
--Lower radiator hose-new 19502-PR4-A00 90-91 Integra
--Upper radiator hose -new 19501-PR3-000 92-93 Integra GSR
--Tokico Illumina Spring & Shock Kit TOK ILK 216 89 Civic Si
--1 rear mount bolt (shorter) 90189-SF1-010 90-91 Integra
--2 rear mount bolts (longer) 90188-SF1-010 90-91 Integra
--Throttle cable 17910-SK7-A03 90-91 Integra
****** I used stock Si throttle cable with homemade bracket)*****
--Shifter stabilizer bolt 95701-08018-08 94 Del Sol DOHC Vtec
-- EXEDY Full Face Racing Clutch/Organic Disk ****(25mm Spline)**** EXEDY 08-804 (includes release& pilot Bearings 90 Integra Cable Trans ONLY **(later yr cable trans have a larger input shaft) **
--Stock Si Clutch cable worked perfectly without Modification 89 Civic Si
--Koyo throwout bearing (installed new) 062-1147-CB-54004 90-91 Integra
--Nachi pilot bearing (installed new) 91006-634-008 90-91 Integra
From: I told you to wait in the truck in Texas, United States
vtec4thgen
Jun 29, 2011 07:55 AM
