FS: TURBO KIT b18 b16 d16 sohc dohc eg6 dc2 WILL PART ohio
due to bs licensing issues i need to sell my kit
happy birthday to me...
now i get to spend all the cash on old out of state tickets...yay...uhg...thud
truly a great ticket story back in connecticut july 4th 2003...
ask me for a good laugh.
i like http://www.escrow.com protects everyone...and i will pay the fee
i also will use paypal...but i dont like it as much...fee on buyer
skyline rb20 dual ceramic ball bearing and ceramic turbine turbo
ultra quick spooler...ceramic turbine good to 1 BAR...stock 9lb internal gate.
comp wheel 42x59 (50.6751 trim)
comp cover .50 a/r
turbine wheel 51x43 (71.0880 trim)
exh. cover ?? a/r (sorry)
this turbo achieves a higher ratio between trims through use of its lightweight components...
cutom made under license to nissan by garrett
t3 inlet...includes stock 6.bolt exh outlet w/ o2 bung already welded to steel 3"
also have a nice 90° comp outlet from an s13
misc piping and 3.bolt flange to help complete downpipe easy.
braided ss oil feed line with brass T fitting to retain oem oil pressure sender
turbo fittings are already installed as pictured for this feed
brand new turbo drain outlet - barbed
also have b16 tapped oil pan barbed as well for easy heater hose oil drain.
b16 tapped pan should also work for b18a b18b LS motors
<FONT COLOR="red">SOLD ::: greddy type.r bov</FONT>
maroon piping includes all couplers and clamps (held over 450hp d16)
piping has bov flange as pictured
revhard fmic - excellent condition
inlet to outlet = 30.5 inches
height = 6.5 inches
core length = 27 inches
thickness = 3 inches
inlet/outlet diam = 2 inches, 2.25 inches
<FONT COLOR="red">SOLDbrand new STR b.series cast turbo manifold</FONT>
OR
<FONT COLOR="red">SOLD ::: brand new turboXS d.series turbo manifold</FONT>
all hardware for each included
misc piping for external wastegate dump if so desired
<FONT COLOR="red">SOLD ::: chipped obd1 ecu</FONT>
can enable/disable vtec and load any basemap with any custom crome free settings for any obd1 setup...including iab control
<FONT COLOR="red">BOOST/OIL SOLD ::: blox white face gauges ::: </FONT><FONT COLOR="green">rpm</FONT><FONT COLOR="red">...boost/vac...oil pressure gauges with oil sender</FONT>
(pic below is for night color representation only)
extra black face oil pressure gauge lighted with fuel nut adapter
(this is for safe in car fuel pressure monitoring)
dual pillar gauge pod
also have a custom black dual pod that replaces complete eg cluster bezel
the gauges are right of the clock/hazard but delete the two center vents
synapse missing link (new in open packaging w/ all hardware)
vortech super fmu sfmu
(the only true fully controllable fmu on the market in my opinion)
you can max the fuel pressure...bleed screw for more of a pressure curve...
set base fuel pressure and have delayed rise based on boost pressure
and much more...includes a/n fittings
<FONT COLOR="red">SOLD ::: brand new WALBRO GSS342 255 lph fuel pump with install kit</FONT>
<FONT COLOR="red">SOLD : RC440s - #SL9-440 obd1 injectors saturated high impedance</FONT>
brand new 3" ractive air filter including cover
probably more i am forgetting
need pictures of anything else let me know
comp cover .50 a/r
height = 6.5 inches
OR
hopefully i dont have to sell everything...
but i will sell anything
d.series ssautomani payment has been received
i think he used e-check or something....awaiting it to clear before ship.
