B16B to 1.8 conversion what pistons
Old Sep 19, 2007 | 01:08 PM
bootlegcivic's Avatar
Default B16B to 1.8 conversion what pistons
Alright, I'm going to be making my B16B a 1.8 using LS crank (stock) and ls rods (eagle) what pistons would I use just b16. The motor is turbo'd already so I'm looking to get 9:1 compression when I'm done down from 10.8:1.
(B16B Block is the same as GSR ITR block with b16/itr head)
Old Sep 19, 2007 | 01:09 PM
Kevlar1's Avatar
Default Re: B16B to 1.8 conversion what pistons (bootlegcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bootlegcivic &raquo;</TD></TR><TR><TD CLASS="quote">Alright, I'm going to be making my B16B a 1.8 using LS crank (stock) and ls rods (eagle) what pistons would I use just b16. The motor is turbo'd already so I'm looking to get 9:1 compression when I'm done down from 10.8:1.
(B16B Block is the same as GSR ITR block with b16/itr head)</TD></TR></TABLE>
sorry but i dont think thats gonna work. stroke is too big for a 1.6 bottom end.
Old Sep 19, 2007 | 01:14 PM
Default Re: B16B to 1.8 conversion what pistons (bthereforyou18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bthereforyou18 &raquo;</TD></TR><TR><TD CLASS="quote">
sorry but i dont think thats gonna work. stroke is too big for a 1.6 bottom end.</TD></TR></TABLE>
the b16b is the same bottom end as an itr or gsr 1.8 bottom end it uses b16a crank with longer rods to make up for the difference in stroke.
Old Sep 19, 2007 | 01:26 PM
gibsanez's Avatar
Nice try though
Old Sep 19, 2007 | 01:28 PM
Kevlar1's Avatar
Default Re: B16B to 1.8 conversion what pistons (gibsanez)
the b16b is the same bottom end as an itr or gsr 1.8 bottom end it uses b16a crank with longer rods to make up for the difference in stroke.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">
Nice try though </TD></TR></TABLE>
well put guys, guess you learn something new everyday
Old Sep 19, 2007 | 01:34 PM
gibsanez's Avatar
well put guys, guess you learn something new everyday </TD></TR></TABLE>
It's basically a de-stroked ITR, with a R/S ratio higher than a B16. Kinda neat, but a little over-priced IMO
Old Sep 19, 2007 | 01:45 PM
any help though???
Old Sep 19, 2007 | 02:06 PM
1.8L_allmotormilitia's Avatar
Just buy a b20 bottom end and you wont regret it.
Old Sep 19, 2007 | 02:59 PM
Kevlar1's Avatar
Default Re: (1.8L_allmotormilitia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bootlegcivic &raquo;</TD></TR><TR><TD CLASS="quote">any help though???</TD></TR></TABLE>
I mean if your using a ls crank and stock ls rods and you want to use stock pistons of the ls.
But in your case then just get some 9:1 je pistons. Get them for the ls block, should turn out the same shouldn't it?
Would like to know as well
Old Sep 19, 2007 | 03:20 PM
cartune network's Avatar
Default Re: (Kevlar1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kevlar1 &raquo;</TD></TR><TR><TD CLASS="quote">
Would like to know as well </TD></TR></TABLE>
it should. if ur gonna go with eagle rods then u have to go with an aftermarket piston. oem pistons wont mount on eagle rods. i would reccomend je though. im using eagle h-beams and je pistons on my gsr.
Old Sep 19, 2007 | 03:21 PM
the thing that gets me is the combustion chamber is larger on a b16/itr head larger than a ls or gsr head. That's why I don't understand.
Old Sep 19, 2007 | 03:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8L_allmotormilitia &raquo;</TD></TR><TR><TD CLASS="quote">Just buy a b20 bottom end and you wont regret it. </TD></TR></TABLE>
I'm turbo not all motor so I need something with some thicker cylinder walls allmotormilitia
Old Sep 19, 2007 | 03:30 PM
ToeJam's Avatar
Default Re: (bootlegcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bootlegcivic &raquo;</TD></TR><TR><TD CLASS="quote">the thing that gets me is the combustion chamber is larger on a b16/itr head larger than a ls or gsr head. That's why I don't understand.</TD></TR></TABLE>
what dont you understand
gsr heads have quench pads for higher compression and is less prone to detonation. In the end they are all matted to 81mm blocks. the size of the combustion chamber (in general) has nothing to do with bore sizes. take a look at a v8 head, for example.
Old Sep 19, 2007 | 03:59 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (ToeJam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ToeJam &raquo;</TD></TR><TR><TD CLASS="quote">
gsr heads have quench pads for higher compression and is less prone to detonation..</TD></TR></TABLE>
Wrong, the gsr head has better quench pads so you can run a very agressive timing map and not detonate.
BTW, the usdm gsr has 10:1 compression.
Old Sep 19, 2007 | 05:55 PM
ToeJam's Avatar
Default Re: (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">
BTW, the usdm gsr has 10:1 compression.</TD></TR></TABLE>
where was i wrong? if i was wrong wouldn't that make you wrong also? you just basically stated the same thing i just did... anyways, good job man!!
Old Sep 19, 2007 | 07:52 PM
ghostskinner's Avatar
if u want stock internals you can use some p72 pistons and if you want after market choose which ever one
Old Sep 20, 2007 | 03:09 AM
RagingAngel's Avatar
Christ *****....
try here for your answers:
https://honda-tech.com/zeroforum/16
You're not getting good replies because it's the ALL MOTOR forum.
Old Sep 20, 2007 | 05:13 AM
mar778c's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ToeJam &raquo;</TD></TR><TR><TD CLASS="quote">where was i wrong? </TD></TR></TABLE>
The gsr head quench pads were not originally designed with compression greater than the stock compression (10.1 usdm or 10.6 jdm).
If you are stating that the quench pads will aid in staving off detonation due to higher compression or agressive timing map that is correct, .
Modified by mar778c at 6:58 AM 9/20/2007
Old Sep 20, 2007 | 07:33 AM
401B18TEG's Avatar
no, it not.
Old Sep 20, 2007 | 07:48 AM
gibsanez's Avatar
Default Re: B16B to 1.8 conversion what pistons (401B18TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 401B18TEG &raquo;</TD></TR><TR><TD CLASS="quote">
no, it not. </TD></TR></TABLE>
The B16B uses a B18C bottom end.
Old Sep 20, 2007 | 07:50 AM
wascly's Avatar
Same deck height as the b18 blocks - yes.
Same stroke as b16a - yes
Longer rods and taller pistons w/ a low wrist pin to make up compression - yes
What exactly are you arguing?
bootlegcivic: why would you want to stroke a b16b when you could just get an LS bottom end and build that to your specs? I am sure there are plenty of people that would take that unmolested b16b off your hands for a decent price.
Old Sep 20, 2007 | 08:44 AM
401B18TEG's Avatar
Misread A TO B, my apologies
Old Sep 20, 2007 | 09:29 AM
kcrxxx's Avatar
Default Re: (401B18TEG)
I'm using P30 pistons- leaving me with around 11.5-1 cr, and require no machining to fit ls rods.
Old Sep 20, 2007 | 09:31 AM
kcrxxx's Avatar
Default Re: (kcrxxx)
Sorry just read the topic- didn't realize you were going turbo. Anyway bump to another stroked b16b
Old Sep 20, 2007 | 12:01 PM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 401B18TEG &raquo;</TD></TR><TR><TD CLASS="quote">Misread A TO B, my apologies</TD></TR></TABLE>
At least you had the ***** to admit your error.
