Anyone can recommend some good oil treatment ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">i have heard "RESTORE" is good..but does anyone use any oil treatment?</TD></TR></TABLE>
IMO, waste of money. any type of additive is a waste of money. and if it does have any affect to the motor, they're most likely at a minimum.
why do you ask?
why do you ask?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
why do you ask?</TD></TR></TABLE>
i have never used any oil treatment on the cars i have owned or ever owned.i am just wondering if there is any oil treatment thats good for the engine..so i guess not..
I heard of changing your oil with tranny fluid for the first 100 miles and then putting oil in. helps with rings and other things. might not be what you're looking for, but check it out before just trying it. do a search for that.
the oil recommendation i can give is stay on top of it. i tell people all the time, if you want your car to last a long time, change your oil on time.
the one easiest thing many people over look.
</TD></TR></TABLE>the oil recommendation i can give is stay on top of it. i tell people all the time, if you want your car to last a long time, change your oil on time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tei344 »</TD></TR><TR><TD CLASS="quote">I heard of changing your oil with tranny fluid for the first 100 miles and then putting oil in. helps with rings and other things. might not be what you're looking for, but check it out before just trying it. do a search for that.</TD></TR></TABLE>
and where did you hear that from?
PUT THE BOTTLE OF OIL DOWN AND STEP AWAY FROM THE VEHICLE!
can you try this for us??
Im curious as to what your results would be from putting tranny fluid in a motor.
Most motor oil aficionados are not big supporters of additives, usually pointing out that a high-quality motor oil does not need anything else to properly protect the engine. That being said, some additives are effective when trying to address a specific issue, so it really depends on what you're trying to accomplish.
