Rad. puking?
Old Sep 19, 2007 | 12:11 PM
Type-r-driver-2000's Avatar
Default Rad. puking?
Ok so I put my motor in this saturday. When I went to bleed the cooling system of air, it would take in fluid and then all the sudden puke it out. I had the motor in before and it bled fine, so I dont think its a head gasket. Any Ideas?
Old Sep 19, 2007 | 12:59 PM
mstewar's Avatar
Default Re: Rad. puking? (Type-r-driver-2000)
if you refill before the fan cycles, it will heat up and come back out.. not sure what else you could mean by "puke out"..
Old Sep 22, 2007 | 07:24 AM
sheekdude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-r-driver-2000 &raquo;</TD></TR><TR><TD CLASS="quote">Ok so I put my motor in this saturday. When I went to bleed the cooling system of air, it would take in fluid and then all the sudden puke it out. I had the motor in before and it bled fine, so I dont think its a head gasket. Any Ideas?</TD></TR></TABLE>
Just let the car run and keep refilling with the rad cap off... just need to be bled. You can also turn the heat on high, this always works for me.
sloassSi
Apr 16, 2010 07:15 PM
eggsi619
Aug 13, 2008 07:24 PM
BoostinEJ1
17
May 19, 2007 04:57 PM
hotvtec
Jul 19, 2004 05:50 AM
4speed
11
Dec 6, 2003 01:06 PM
