Will this work? Has anyone done this before?
I know this is some bad photoshop, but I'm wondering, has this been done before in a EG model? I'm planning on getting either the Kenwood, Eclipse or Pioneer DVD/Navigation headunit and want it installed there and have my ac/heater control down there. If ANYONE has done this, PLEASE post some pic so i can see. Thank you for any comments!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MinuteRice »</TD></TR><TR><TD CLASS="quote">You can fit a double din in the HOP optional center console a lot easier. </TD></TR></TABLE>
true...but it's too low...i want the screen in a "more" visable view.
Should be do-able.. the only thing that might give you a problem is the air temp mix cable, as long as its long enough, and you can route it without kinking it, the install shouldn't be too bad..
Start taking things apart and see how you are going to do.
Good Luck..
Good Luck..
The climate control cables will never work quite right. And w/out some extensive fiberglassing, it's not going to look clean.
Given the tradeoffs I'd spring for the optional console and put it down there. Or I'd just buy an Integra (whoops, already did).
