Honda S2000 Honda S2000
Installing Low Impedance / Peak Hold injectors
Old Sep 18, 2007 | 09:25 PM
BioXide02's Avatar
Default Installing Low Impedance / Peak Hold injectors
How would I go about installing Low Impedance / Peak Hold injectors into an S2K? My friend is wanting to turbo his S2K and I have some 880cc Peak and hold injectors that he wants to buy off of me to use in his setup.
Thanks in advance.
Old Sep 18, 2007 | 09:31 PM
BioXide02's Avatar
Default Re: Installing Low Impedance / Peak Hold injectors (BioXide02)
Also they are precision injectors.. Just wanting to make sure we can get these to work before I sell them to him.
Old Sep 19, 2007 | 07:17 AM
fridaytech's Avatar
sorry man your buddys s2000 should run.
High impedance/resistance (saturated) 12-16 Ohms.
Old Sep 19, 2007 | 08:44 AM
BioXide02's Avatar
Default Re: Installing Low Impedance / Peak Hold injectors (fridaytech)
I know that S2000's are High impedance/resistance.. I am asking how to make them work? Wire in resistors in the line? Do a resitor box?
Just trying to make sure it is no diff than doing it on say, an EG or whatever.
Old Sep 19, 2007 | 12:43 PM
fridaytech's Avatar
look into it for you....
Old Sep 19, 2007 | 02:50 PM
fridaytech's Avatar
Saturated injectors require roughly 1-1.5 amps to open the injector. Peak & hold injectors initially needs about 4-6 amps, and once open drops to roughly 2-3 amps to keep it open.
these are not exact numbers for s2000 but an over view. with this info i would say why do all the trouble of trying to make them work. Just buy the wright stuff and be done with it
Old Sep 19, 2007 | 02:59 PM
BioXide02's Avatar
Maybe he needs bigger injectors than what saturated injectors has to offer?
Common, I know people are making over 500 hp in s2k's.. What are they doing to run the peak and hold injectors.
Old Sep 19, 2007 | 03:49 PM
fridaytech's Avatar
aem Peak & Hold Injector Driver Module
Old Sep 19, 2007 | 07:38 PM
S2000Forsale's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BioXide02 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe he needs bigger injectors than what saturated injectors has to offer?
Common, I know people are making over 500 hp in s2k's.. What are they doing to run the peak and hold injectors. </TD></TR></TABLE>
all you need to do is buy a OEM resistor box and wire the box. inlinepro use this method.
i will be doing the same think
Old Sep 19, 2007 | 09:05 PM
BioXide02's Avatar
Default Re: Installing Low Impedance / Peak Hold injectors (S2000Forsale)
Where do you wire the reisitor pack in at on the S2000's?
I know on OBD1 cars it is Near the brake master cylinder.. But I have no clue on the S2k's.
Anyone have a picture?
Old Sep 20, 2007 | 03:05 PM
BioXide02's Avatar
Old Oct 12, 2007 | 11:26 AM
boostedblkef's Avatar
the cheap way is to go to radio shack and buy 10 ohm in line resistors there like 15 cents each and wire them in line of the injectors and buy some bigger wire loom to hide them in total 5 bucks and 15 min time or find any resistor box and wire injectors to that
Old Oct 12, 2007 | 11:57 AM
BioXide02's Avatar
Default Re: Installing Low Impedance / Peak Hold injectors (prospeed performance)
Thanks for the reply
CaliforniaDad
Aug 14, 2011 01:55 AM
jdmxefxsi
Feb 9, 2011 09:43 AM
hondaaccord94
Jan 16, 2006 06:55 PM
pissedoffsol
Nov 21, 2003 11:46 AM
