Cracked a bolt!!!
Old Sep 18, 2007 | 07:43 PM
tpdc2's Avatar
Default Cracked a bolt!!!
Ok im freaking out about this right now so i need to know if anybody can help me. I was changing my fuel injectors today and when retightening my fuel rail bolts (connect to the intake mani) the bolt cracked and is now lodged in the middle section. Does anybody know a way to get the bolt out without ruining my s2 intake mani? Or does this bolt being broken even matter?
Old Sep 18, 2007 | 07:55 PM
all-mtr-teg's Avatar
Default Re: Cracked a bolt!!! (tpdc2)
Use a bolt extractor if possible, if not, you can weld on a nut and back it out, i did that this weekend on a power steering pump bolt and an oil pump bolt.
Old Sep 19, 2007 | 04:00 AM
tpdc2's Avatar
Default Re: Cracked a bolt!!! (all-mtr-teg)
where would i be able to get a bolt extractor and how much would it cost? I might be able to get my hands on a welder but it would take a while to get ahold of one of my friends with one.
Old Sep 19, 2007 | 05:32 AM
Doostur's Avatar
Maybe get it drilled out?
Old Sep 19, 2007 | 07:18 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpdc2 &raquo;</TD></TR><TR><TD CLASS="quote">where would i be able to get a bolt extractor and how much would it cost? I might be able to get my hands on a welder but it would take a while to get ahold of one of my friends with one.</TD></TR></TABLE>
http://www.harborfreight.com/c...40349
Old Sep 19, 2007 | 09:05 AM
tpdc2's Avatar
Default Re: Cracked a bolt!!! (AWD Terror)
thanks hopefully it works
Old Sep 19, 2007 | 11:51 AM
just use a center punch before you start drilling to make sure your hole will be centered. Good luck
poolpool8
Apr 1, 2017 09:12 PM
DARKTEG_
Oct 9, 2006 08:32 PM
88 rex
Jul 24, 2003 02:18 PM
