99 hb lsvtec Brake/supension budget build
hello, ive been around for a while
decided to post a build thread
this is my 99 hb dx
it has an lsvtec
and a 100 shot of nitrous
no i'm in the precess of piecing together a BBK from parts i have laying around from other projects.
i have front calipers/rotors from a 2007 acura TL AT that i did a stop-tech BBK install on.
and i have a complete DA F/R brake swap from an old DA i owned
from reading this
https://honda-tech.com/zerothread?id=1811368
i have decided to bolt on the rear DA brakes and use the knuckles from the DA and the TL calipers and rotors.
but i run into this delema...
the pistons seems to be the same size and the pad surface area on the rotors are the same.
rotor
DA 10.3" .75" thick
TL 11.8" 1.4" thick
pads are almost identical
2x5"
but the tl is more consistent
calipers
DA 7" long
TL8.25" long
but i know for sure that one of the DA calipers needs a rebuild....
what to do?
is the extra weight worth the little extra brake pad area?
are the pistons different?
would it just look better?
discuss
Modified by formby at 11:45 AM 9/19/2007
this is my 99 hb dx
it has an lsvtec
from reading this
rotor
DA 10.3" .75" thick
TL 11.8" 1.4" thick
2x5"
calipers
DA 7" long
TL8.25" long
what to do?
discuss
Another_Si_Guy
Feb 6, 2015 12:26 AM
