neuspeed springs 1.8f/1.7r with stock shocks good or bad
i want to know if this is good or bad to do i am seariously tight on cash and i am not looking for the best performance because of lack of money would this be a bad set up till i can get shocks? i dont want to scrape but i want my car looking better. its a 6th gen 2 door accord v6 vtec.
I'll suggest on saving enough money for both springs and upgrade shocks. So you can do both at once, instead of having to do it twice when u get new shocks.
if your straped on cash and want a lowered ride for now then go ahead and get the springs, as long as your planning on upgrading your dampers later on when you can afford it and dont mind doing the work twice (which sint a big deal, the accords suspension is very easy to work on). just keep in mind with the new springs and stock dampers your ride will be under dampened so dont try to be schumacher on the freeway on ramp to work.
^^^yea pretty much what he said.......once that strut gives out your spring will sag permantly......and when u do finally plan on upgrading your struts you will have a spring problem.......just do it rite the first time you will b happier trust me im in the same situation as you....
SL!M
Jun 24, 2003 06:08 PM
crxaddikt
Sep 6, 2002 05:41 AM
