WTB: OBD2 B16,GSR,LS Block/Swap
Old Sep 18, 2007 | 06:15 PM
98ej8coupe's Avatar
Default WTB: OBD2 B16,GSR,LS Block/Swap
like what it says..show me what u got
Old Nov 28, 2007 | 10:51 AM
98ej8coupe's Avatar
Default Re: WTB: OBD2 B16,GSR,LS Block/Swap (98ej8coupe)
upp
Old Nov 29, 2007 | 04:09 PM
98ej8coupe's Avatar
upp
Old Nov 29, 2007 | 10:01 PM
98ej8coupe's Avatar
ttt
Old Nov 30, 2007 | 02:30 AM
DaveF's Avatar
you looking for a complete swap or something you can build up?
Old Nov 30, 2007 | 07:38 AM
98ej8coupe's Avatar
Default Re: WTB: OBD2 B16,GSR,LS Block/Swap (DaveF)
anything as long as its obd2 im wanting a b16 or a gsr
Old Dec 1, 2007 | 08:14 AM
98ej8coupe's Avatar
bumppp i want obd2 b16 or gsr
Old Dec 1, 2007 | 02:22 PM
bleedblue94's Avatar
if you change your mind i have an ls
Old Dec 1, 2007 | 09:34 PM
killercannible's Avatar
Default Re: WTB: OBD2 B16,GSR,LS Block/Swap (bleedblue94)
i know you want an obd2 b16 or gsr, but the only difference in the blocks is the crank fluctuation sensor on the oil pump. If you buy an obd2 b series oil pump and put a crank fluctuation sensor(can be sourced from your d series) on it then it is exactly the same.
Old Dec 2, 2007 | 07:21 AM
HondaCivicSiR1's Avatar
Default Re: WTB: OBD2 B16,GSR,LS Block/Swap (killercannible)
pm'd you
2000csi
Jun 25, 2010 10:33 PM
grant97teg
Apr 20, 2009 11:02 AM
jdmgeezer
Oct 10, 2007 11:06 PM
pkgwjai082
Jun 3, 2005 12:03 AM
