d15b7 exhaust manifold
Old Sep 18, 2007 | 05:39 PM
onpointones's Avatar
New User
Default d15b7 exhaust manifold
Whats good H-Tech this is my first post. I just put a d15 from a 93 civic in my 89crx HF the manifold don't bolt to my exhaust system what can i do. Will a d16 from a crx bolt up to the block.
Old Sep 18, 2007 | 05:58 PM
STREETWERKZ's Avatar
Default Re: d15b7 exhaust manifold (onpointones)
what sort of exhaust do you have?
i'd try the manifold that came with the engine.
Old Sep 18, 2007 | 06:36 PM
DelSolDon's Avatar
Default Re: d15b7 exhaust manifold (STREETWERKZ)
since he has a CRX HF, it would originally have the short manifold with the cat positioned in front of the engine. in order to use the D15B7 manifold, you will have to remove the downpipe that is currently there running under your oil pan and add a catalytic converter (or test pipe) between the end of the D15B7 manifold and the rest of the exhaust.
or if you have the HF manifold and cat, just use those on the B7 head.
Old Sep 19, 2007 | 05:17 PM
New User
Default Re: d15b7 exhaust manifold (DelSolDon)
Did i get u right u said my HF manifold should work on the b7
Old Sep 19, 2007 | 05:52 PM
DelSolDon's Avatar
yep, same bolt pattern
Battle2.0Eg
Honda Civic (2001 - 2005)
Sep 30, 2010 11:39 PM
Youlose1305
Jul 28, 2006 11:43 AM
dank9513
Jun 13, 2003 06:04 PM
HtC_SiR
Apr 30, 2003 07:32 AM
rexinfection
Oct 31, 2002 01:17 PM
