rolled fenders?
alright well, I just got my camber kits put on and i ran into a problem with the fenders rubbing my tire. Someone told me rolling my fenders in addition to smaller tires will give me my stance back. What type of shops normally roll fenders? or where to get it done at?
I rolled mine using a wooden baseball bat and a rubber mallet ... worked great!!
just jack the car up so you can get the bat inbetween the tire and fender ... slowly lower the car down until the bat is wedged in there and roll it back and forth over the top of the tire ... just keep repeating this until the fender clears the tire! You can use the rubber mallet to knock down sharp edges if you get any ... or if you really need to *massage* the fender!
Modified by FullEP3 at 12:29 PM 9/19/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FullEP3 »</TD></TR><TR><TD CLASS="quote">fender rolling tools are for sissies and stunna show kahs ... jk
Get Creative!!
DO NOT USE A BAT OR ANYTHING OTHER THAN THE PROPER TOOL. I used a bat and chipped paint. I rented a fender roller that day. Works perfect and is worth the money to rent. Do it right the first time. I wish I did. I had to repaint.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NTCustoms »</TD></TR><TR><TD CLASS="quote">fronts can be rolled if you remove the fenderlining.</TD></TR></TABLE>
Go out and look at your front fender if you think you can roll it. The lip is only like 5mm; it's pointless. If you're rubbing up front, you'll have to figure out a different way (smaller rims/tires or raise the car).
Get Creative!!
</TD></TR></TABLE>DO NOT USE A BAT OR ANYTHING OTHER THAN THE PROPER TOOL. I used a bat and chipped paint. I rented a fender roller that day. Works perfect and is worth the money to rent. Do it right the first time. I wish I did. I had to repaint.
talkJDM
Suspension & Brakes
13
Jul 25, 2011 06:20 AM
tunedek
May 31, 2004 10:09 PM
