power folding mirrors wiring diagram and yes i searched
Old Sep 18, 2007 | 03:50 PM
1kleenef's Avatar
Default power folding mirrors wiring diagram and yes i searched
i would like to kno if anyone has a diagram for these mirrors because all the archived ones have links that dont work so if ne one has this it would be greatly appreciated thanks
Old Sep 18, 2007 | 04:40 PM
J_CRX's Avatar
Default Re: power folding mirrors wiring diagram and yes i searched (1kleenef)
If you got a 5 wires diagram, this will help you out.
I got mine with 8 wires because it has an optional heated mirror as well. I didn't hook up the heated mirror because I don't have the right switch for it, and the diagram (up there) doesn't work so well for me because all my wires are different colors. You can use a volt meter and play around with it and you can figure it out like I did.
And here is what it like once installed..click the link at the bottom..I made a video clip because someone requested it a while back..peace!!
http://s36.photobucket.com/alb...9.flv
Old Sep 18, 2007 | 04:57 PM
1kleenef's Avatar
Default Re: power folding mirrors wiring diagram and yes i searched (J_CRX)
thank you i will find this extremely helpful when installing them later on thank you
Old Sep 18, 2007 | 05:22 PM
89hatcher's Avatar
only got my mirrors to fold in and out with out the stock relays and switch so i happend to hook it up to my alarm so when i arm my alarm it will fold in and when i disarm it fold out.
Old Sep 18, 2007 | 05:58 PM
1kleenef's Avatar
Default Re: (89hatcher)
thats kewl do u have a setup or writeup about how u did that ive heard people doing that but i still want the switch and relays as a security and safety thing dont want to melt ne wires
Old Sep 18, 2007 | 09:39 PM
J_CRX's Avatar
Default Re: (1kleenef)
It's a nice idea but I personally don't like hooking anything up to my alarm. Personally, I think by doing this, you will wear out the motor for your folding mirrors faster..then you're gonna have to find another set. I like to have the option of doing the folding in and out manually because there are less chances of some jerks parked like 2-3 inches next to your car, and when you hit your alarm to get into your car, your mirrors fold out and break against his car.
But if that's what you are interested in doing. Find the wire on your mirror switch fold in/out button that send power/voltage to your folding relay. Tapped into that wire, and run that tapped wire into your power/voltage of your alarm automatic door actuator. This will be in a parallel circuit, which doesn't cause extra resistances to your alarm or your folding mirrors. But make sure you test everything first before hooking anything up, and always use circuit protector(s). Good luck
Old Sep 19, 2007 | 12:44 AM
89hatcher's Avatar
Default Re: (J_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J_CRX &raquo;</TD></TR><TR><TD CLASS="quote">It's a nice idea but I personally don't like hooking anything up to my alarm. Personally, I think by doing this, you will wear out the motor for your folding mirrors faster..then you're gonna have to find another set. I like to have the option of doing the folding in and out manually because there are less chances of some jerks parked like 2-3 inches next to your car, and when you hit your alarm to get into your car, your mirrors fold out and break against his car.
But if that's what you are interested in doing. Find the wire on your mirror switch fold in/out button that send power/voltage to your folding relay. Tapped into that wire, and run that tapped wire into your power/voltage of your alarm automatic door actuator. This will be in a parallel circuit, which doesn't cause extra resistances to your alarm or your folding mirrors. But make sure you test everything first before hooking anything up, and always use circuit protector(s). Good luck </TD></TR></TABLE>
actually i don't think that the motor will burn out if you hook it up to the alarm the circuit will cut off after just like the oem power windows. when the window goes all the way down the power cuts off and the motor stops. thats the same thing with the mirrors. and so is the jdm power switch. when you push the button for the mirrors to fold in it is grounded and the button stays in. also i hooked it up so when i disarm the alarm it woul not fold out right away. i hooked it up to a channel like the trunk popper signal then it would fold out.
Old Sep 19, 2007 | 01:01 AM
J_CRX's Avatar
What I meant is not by burning out. When you fold in and out, the folding mirror motor are in used, and is slowly wearing out from stressed. When you hook it up to your alarm system, the mirrors get folded in and out more often then it would if you were to fold them manually with a push of the fold button.
Old Sep 19, 2007 | 11:40 AM
89hatcher's Avatar
Default Re: (J_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J_CRX &raquo;</TD></TR><TR><TD CLASS="quote">What I meant is not by burning out. When you fold in and out, the folding mirror motor are in used, and is slowly wearing out from stressed. When you hook it up to your alarm system, the mirrors get folded in and out more often then it would if you were to fold them manually with a push of the fold button.</TD></TR></TABLE>
i get what your saying. why would it be slowly wearing out from stress...in japan they use it a lot also because there roads are not as wide and are often used.
Old Oct 20, 2007 | 01:33 PM
CleanBlk90si's Avatar
Hi everyone ... I would like to know if anyone here can tell me where i can locate the power mirror relay on a 1991 Civic LX. Thanks!
Old Nov 17, 2007 | 02:00 PM
jairot22's Avatar
hello i used your diagram and i got my mirrors to move up down side to side,but cant get them to fold.the i check the blue wire coming from the relay and has positive pulse when i push the button.i have a red,two black and a black with white wires not connected yet. do you know which one is for the folding function?i would really appreciate your help
Old Mar 2, 2008 | 11:02 PM
vtecn8ive's Avatar
Default Re: power folding mirrors wiring diagram and yes i searched (jairot22)
bump for useful knowledge :D
J_CRX
16
May 11, 2007 10:10 AM
Savage211
Aug 9, 2006 09:31 AM
91cvcsi
12
May 5, 2005 08:23 PM
Cowiebunga
Apr 21, 2005 04:48 AM
johnny hatchback
Apr 11, 2003 09:59 AM
