Will a '88 or '91 CRX Si transmission bolt on a SOHC ZC???
Will a 1988 or 1991 CRX Si transmission bolt on my SOHC ZC Engine??
I have 1990 civic hatch with ZC swap. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 »</TD></TR><TR><TD CLASS="quote">D series transmissions fit in all d series engines with the exceptions of going from cable to hydraulic.</TD></TR></TABLE>
Nope, sorry.
Try bolting up a D16A1 trans. to any other D-series engine. There's also the issue of 88 transmissions on non-88 vehicles.
Hydro transmissions will bolt up as well, but the mounts are different.
Nope, sorry.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 »</TD></TR><TR><TD CLASS="quote">Obtain an SI. The best d series transmissions.</TD></TR></TABLE>
Somebody's trying to boost their post count in a hurry...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 »</TD></TR><TR><TD CLASS="quote">It will also bolt up to Dohc ZC.</TD></TR></TABLE>
OK, seriously. Knock it off.
Read this https://honda-tech.com/zerothread/2086185 No negative comments please. Just helping Jonny Rocket out. I will knock it off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 »</TD></TR><TR><TD CLASS="quote">Read this https://honda-tech.com/zerothread/2086185 No negative comments please. Just helping Jonny Rocket out. I will knock it off. </TD></TR></TABLE>
Helping out or post whoring? Have you not seen that I already warned you?
The only post whoring i seen here is the guys complaining that some one is post whoring LMAO, and I will go with the crowd here i def like the SI tranny better even if it revs higher on the highway a little.
Dont forget about the ZC trans. It will bolt up to a A6 Z6 and Y8. only thing is that on the z6 and y8 you will have to tap the back of the block for the int shaft bolts. Closer gears but final drive sucks...
flatblackfury91
Sep 12, 2012 05:40 AM
I Gotta Question
Dec 17, 2002 03:22 PM
