lil expertise needed with this problem plz .........starter problem or so i thought
Old Sep 18, 2007 | 12:27 PM
Jay Blazed's Avatar
Default lil expertise needed with this problem plz .........starter problem or so i thought
ok .....recently had the auto tranny from my 94 ls replaced with manual gsr. ( 2k miles ago)
The starter sounded like it was slowing down....( you gotta know what i mean) ya know the sound ......every honda has that unique sounding starter ya know
So this mornig it totally wouldnt start.....had to pop the clutch
after the ride home ( and stop @ autozone for a new starter) i tried to start it up again ....it worked ....bearly ...just sounded really weak
so ok i replaced the starter and now it starts up ( only tried it 3x) but it still sounds really weak....
any suggestions......im gonna try to start it up again later......does anything have to sit for a while.....i mean it just a starter.......
ot was the starter not my problem at all?? ty for reading........
Modified by Jay Blazed at 7:08 PM 9/18/2007
Old Sep 18, 2007 | 12:37 PM
Jay Blazed's Avatar
just tried again 15 mins later.....same sounds
it sounds like something is killing my starter....
Old Sep 19, 2007 | 04:02 AM
Jay Blazed's Avatar
plu si forgot to mention.....after the swap, i could start my car w/o pushing down the clutch
is that bad and could it have anything to do with my problem??
thanx again
Old Sep 19, 2007 | 04:24 AM
mmuller's Avatar
Mad Scientist
Default Re: (Jay Blazed)
is your wiring all goody good?
all wires to starter
battery?
Old Sep 19, 2007 | 04:59 AM
mgags7's Avatar
I would say you have a bad battery, or the wiring is bad, as mueller said.
Do you mean that you can start the car with it in gear and the clutch out, and it doesn't move?
or that you can start it just without pushing the clutch in, with it in neutral, it will start right up? If so, that is because when you do a manual swap, if you don't wire up the neutral safety switch, the car will behave like that. Either wire it in or get used to it. I did a long time ago.
Old Sep 19, 2007 | 07:53 AM
Jay Blazed's Avatar
oh no only in nuetral ....lol sry
ya its no big deal about pushing in the cluth, just wanted to throw it in there....
ill check battery next
starter is a pretty simpleplug and play right...
just those 2 wires...
Old Sep 19, 2007 | 08:20 AM
DeadVet's Avatar
If the starter is sounding "weak" then you most likely have a failing battery.... Test it and let us know
professorman
Mar 18, 2013 10:44 AM
chr0nz
Jun 3, 2010 05:20 PM
M1SCO15
Feb 19, 2008 04:51 PM
civicbro
Feb 19, 2004 02:47 AM
crx1856
Aug 20, 2003 10:24 PM
