JDM gauge clusters
Old Jun 17, 2002 | 11:32 AM
sk4sk4's Avatar
Default JDM gauge clusters
does anyone have any pictures on an installed JDM ITR gauge cluster lit up at night? also, does anyone have any experience with the installation of these things? i'm wondering if it's as easy as retailers say it is. thanks for the info guys. fyi i have a '98 GSR. thanks.
Old Jun 17, 2002 | 11:38 AM
BDiddy's Avatar
Default Re: JDM gauge clusters (sk4sk4)
Ive read many different ways of installing. Unfortunatly its not as easy as plug and go. I think the best way to do it is to just change the needles. Then you keep your MPH and miles driven while getting the yellow glow needles. The backround is the same color as USDM.
Old Jun 17, 2002 | 12:20 PM
tecnic1's Avatar
Default Re: JDM gauge clusters (B-DIDDY)
I accadentaly bought a 98-01 JDM ITR cluster off ebay, and I'm not sure what I've gotten into. Will it work on the USDM ECU? I don't care about kilometers or the odometer, I just want it to work, and of course, look bling bling.
Old Jun 17, 2002 | 12:25 PM
Dave-ROR's Avatar
I actually have one for sale right now.. IM me if interested.. 18-19k kilos IIRC. To make it work in any Teg do this.
1. Take out stock USDM gauge cluster.
2. Remove black plastic cover from white "frame" on USDM cluster. (three screws and some clips all around)
3. Remove all gauges from USDM cluster.
4. Remove fake CF plastic cover from white "frame" on JDM cluster (three screws and some clips all around)
5. Remove gauges from JDM cluster.
6. Install JDM gauges into USDM white "frame".
7. Install either USDM or JDM plastic cover.
8. Install in car.
Now if you want the USDM odometer on the JDM gauge face you can take off the needles and swap faces, that way the ODO stays correct and needle (assuming you isntall it correctly) will point to the normal speedo's markings so it will be WAY off on the face but if you remember that 40 was there, 60 was there, etc you'll be fine, or just base speed on RPM..
Old Jun 17, 2002 | 12:29 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: JDM gauge clusters (01_Yeller_ITR)
...will point to the normal speedo's markings so it will be WAY off on the face but if you remember that 40 was there, 60 was there, etc you'll be fine, or just base speed on RPM..
Or you could use tape and make your own speedo markings, right Dave?
Old Jun 17, 2002 | 12:32 PM
Dave-ROR's Avatar
Default Re: JDM gauge clusters (Splat)
LOL can't post pics of that, it's on my old HD at home and new box is dead right now
and that was the previous owner of my MDM nissan that did that! haha
Old Jun 17, 2002 | 12:35 PM
tecnic1's Avatar
thanks...I really did accadentaly buy this thing, I'm sorta excited though...My first JDM part!!!
Old Jun 17, 2002 | 12:38 PM
ITRfaithful's Avatar
i installed a 98 itr cluster on my 94 gsr, and it works perfectly. just take out the old one and pop the new one in and thats it. easy as ptype's mom after a bottle of cristal.
Old Jun 17, 2002 | 12:40 PM
Dave-ROR's Avatar
Default Re: JDM gauge clusters (b18newbie)
That's a 94 GS-R. The motherboards are different on 96 spec ITR clusters and on later USDM cars. There's actually quite a few different ones. A 95 GS-R cluster wont work correctly in a 98 (yes, I've tried in a "customers" car before), older GS wont completely work in a 98 ITR, etc. Usually temp/fuel gauge and some lights are funky.. and some JDM clusters have a bouncy speedo with the JDM motherboard in newer integras.
Old Jun 17, 2002 | 12:56 PM
Mike K's Avatar
My friend tried to run a 00 ITR cluster in his 95 GSR, and it worked, except the fuel gauge didn't work and the 'door open' icon was constantly on.
He ended up just using all the ITR gauges and put them in the background and bezel of his GSR cluster. Now it works fine.
Old Jun 17, 2002 | 12:59 PM
Dave-ROR's Avatar
Default Re: JDM gauge clusters (Mike K)
and an older cluster lights up the ABS light for seatbelt in a newer car
like I posted (and Mike's friend did) just swap the gauges. Easy, no hassle, no ******* around and cutting up the motherboard and soldering jumpers, just 10 minutes of time.
But, TRY the cluster first, it might work, it will vary depending on the year/trim level you have and which year/trim level cluster you are trying to use.
Old Jun 17, 2002 | 03:01 PM
sk4sk4's Avatar
ttt
Old Jun 17, 2002 | 04:08 PM
Comp97GSR's Avatar
I was reading somewhere that if you hook up the JDM one to a USDM car that the odo works in mph... anyone else?
[Modified by Comp97GSR, 1:08 AM 6/18/2002]
Old Jun 17, 2002 | 04:12 PM
tecnic1's Avatar
SO will this cluster from a 98-01 JDM ITR work in my 00 ITR as a direct swap, providing the cluster is really from the car it is supposted to be from?
Old Jun 17, 2002 | 04:23 PM
Comp97GSR's Avatar
Default Re: JDM gauge clusters (tecnic1)
It should. You have to remember that most of these parts come from wrecked ITR's in Japan and prob from a salvage yard so it really depends on the condition of the cluster. I have a 1995 JDM ITR (non-airbag) cluster in my 97 GSR and all gauges worked fine.
Old Jun 17, 2002 | 04:54 PM
JDMITR222's Avatar
Default Re: JDM gauge clusters (Comp97GSR)
Well i bought a JDM cluster with the Mugen speedo.My fuel does not register,what do i need to do?.Everything else works fine except that.
Old Jun 17, 2002 | 05:20 PM
Scorpaznatica's Avatar
New User
Please excuse the funky speedometer . "Zebra R" strikes again.
Old Jun 17, 2002 | 08:18 PM
sk4sk4's Avatar
Default Re: JDM gauge clusters (spooGEN)
whoa how did u do that man??? that's dope.
Old Jun 17, 2002 | 08:21 PM
SpecR_EK's Avatar
New User
The cluster will not read in MPH, only KM/H. On USDM and JDM cars the VSS signal is the same. The mechanism that moves the needle is made to read only in KM/H.
Old Jun 17, 2002 | 08:38 PM
Saga's Avatar
Default Re: JDM gauge clusters (SpecR_EK)
No it will not bolt on. 00-01 USDM ITR owners will not find anything that can bolt right on. They still need to swap the gauges.
94-97 JDM cluster => 94-97 USDM integra
98-01 JDM cluster => 98-99 USDM integra
good call.
Old Jun 18, 2002 | 05:49 AM
Dave-ROR's Avatar
Default Re: JDM gauge clusters (JDMITR222)
Follow the directions I clearly posted earlier in this thread.
-Dave, who is amused by people that don't read.
Old Jun 18, 2002 | 12:20 PM
tecnic1's Avatar
Default Re: JDM gauge clusters (Saga)
good enough. I sorts want it to read in KPH, If I'm going to have a JDM part, It's gotta be JDM, anything worth screwing up is worth screwing up right.
<---brandon, who was once very anti-JDM
Old Jun 19, 2002 | 10:18 AM
makibaka's Avatar
Is there some sort of special tool or procedure for taking out the gauge needles? I've been trying to pull off the yellow needles off my JDM cluster, but I get to the point that I feel like I'm going to break the thing. Should I just stop being a wuss and pull hard until it pops off?
Old Jun 19, 2002 | 10:29 AM
BlueR's Avatar
Default Re: JDM gauge clusters (makibaka)
all the guages work fine...the only things that are off are the idiot lights...ABS light turns off when i put on seatbelts...etc...the only thing that stay on all the time is the check engine light
[Modified by BlueR, 2:33 PM 6/19/2002]
Old Jun 19, 2002 | 10:38 AM
Dave-ROR's Avatar
Flathead screwdriver on the center part where the needle connects to the gauge. Make sure you reinstall at the right spot (which isn't "0")
