1993 Civic Power Window issues
I have been having problems with the power windows on my 1993 Honda Civic LX 4 Door car, it started when the front passenger window would sometimes not go up or down and then when I would power down my drivers side window all the way the passenger window would all of a sudden go up and down. Unfortunately the problem has worsened and now sometimes the drivers side window will stop working. I removed the door panel and clean the contacts and reseated the connector to the master window switch a few times and the passenger window worked for a short while, but then simply stopped working and then will work again or will work but the passenger side window will stop working. I have just replaced the driver side master window switch, and the problem is still happening, so it wasn't the switch. Any idea's ?
Do you have A Multimeter? Does you're passenger side window switch work right and Its judt the Drivers side (passenger window switch) that doesnt work properley?
When the passenger window is having issues the passenger can power down the window but can not power up the window unless I power down my drivers window all the way down and then the passenger can use their window in both directions.....strange
I just bought a multi-meter.
gsaldana10
Honda Civic (2001 - 2005)
May 16, 2017 08:47 AM
92-CivicLX
Sep 23, 2013 07:46 AM
