Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Oil at half point on dip stick?
Old Sep 18, 2007 | 09:28 AM
lando griffin's Avatar
Default Oil at half point on dip stick?
I just checked my oil today and it's in between the bottom and top dot. Car has around ~1,900 miles. It's a 07 Si btw... Is this normal?
Old Sep 18, 2007 | 09:38 AM
IT GUY's Avatar
Default Re: Oil at half point on dip stick? (username34)
I think it's pretty normal. It's been discussed here before. I "used" a little oil before my first oil change, but not a drop since and I'm at 12.5k
Old Sep 19, 2007 | 08:35 AM
ekb16's Avatar
the new 06+ si takes 5.2 qt of oil..if you put 4.6 like the manual says then after you start the car and check ur dipstick its gonna be alittle below the half mark...if you put 5.2 from the beginning then its gonna be pretty much at the top line or very close after you start the car and check your dipstick
Old Sep 19, 2007 | 09:09 AM
Tam N's Avatar
Default Re: Oil at half point on dip stick? (IT GUY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY &raquo;</TD></TR><TR><TD CLASS="quote">I think it's pretty normal. It's been discussed here before. I "used" a little oil before my first oil change, but not a drop since and I'm at 12.5k </TD></TR></TABLE>
Lucky bastard. I burned 1 qt before first oil change (4600 miles) and I've had to add another half a qt since then (6800 miles). Bleh
Old Sep 19, 2007 | 07:29 PM
dtorreskater's Avatar
Default Re: Oil at half point on dip stick? (username43)
is that the first time you checked your oil? your dealer at pdi probably forgot to check oil level or add not uncommon at some dealers
Old Sep 19, 2007 | 09:06 PM
IGotNoSwap's Avatar
Default Re: Oil at half point on dip stick? (dtorreskater)
thats common on si's. most cars usually see 1-1.5 qts burn up within the first 5,000 miles but after that.....you shouldn't burn/lose any oil after that period.
p3terson17
30
Jan 21, 2009 08:12 PM
EK_B
Oct 28, 2007 02:39 PM
EJK20R
Nov 28, 2006 11:13 AM
andyep3
Apr 20, 2005 06:53 AM
speedymon
Nov 29, 2004 05:28 PM
