Mugen Twin loop for DC2
Just bought a used Mugen twin loop exhaust for DC2....My question is....will it bolt directly to my LS without modifications???? Tried searching but no luck....THanks in advance!!
Gee..thanks guys for your quick response...will try to fit it in two days time..will let you know and will post pix of it after fitting!! Thanks again!!
Modified by LoNgHoRn at 4:49 AM 9/19/2007
It depends on where you obtained it. The JDM Mugen systems require the JDM catalytic converter, which is slightly larger at the outlet compared to USDM. If the system was imported and modified by King Motorsports, it should bolt up directly. It will be obvious if a new flange was installed in front of the resonator.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project95LS-VTEC »</TD></TR><TR><TD CLASS="quote">Ah, I love how they sound...</TD></TR></TABLE>
What do you mean? It is quiet, just how I like it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoNgHoRn »</TD></TR><TR><TD CLASS="quote">it came from a JDM ITR.....mine's a USDM LS......</TD></TR></TABLE>
The three bolt holes for the catalytic converter are on a larger bolt circle than your USDM catalytic converter. You could grind them slightly towards the inside to make it fit. This will also result in a slight step in the pipe diameter. Perhaps you could order a custom flanged catalytic converter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91redteg »</TD></TR><TR><TD CLASS="quote">why does the cat matter? its just an axle-back right?</TD></TR></TABLE>
The DC Integra twin loop exhaust was sold only as a cat-back. Some Civic models had axle back versions offered.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoNgHoRn »</TD></TR><TR><TD CLASS="quote">Aight bro.....will take note of all your advises....will let you know as soon as I installed it on my TEG.....and yes..it's and axle-back only....cheers!</TD></TR></TABLE>
If you didn't get the mid-pipe, you will need one that matches the muffler inlet.
Like I said before, Mugen did not sell just the muffler for the DC2 Integra. However, shipping the midpipe from Japan is a royal hassle unless you have a cargo container.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">The three bolt holes for the catalytic converter are on a larger bolt circle than your USDM catalytic converter.</TD></TR></TABLE>
Are you certain of this? I'm aware that "JDM-length" exhausts differ in overall length compared to their USDM counterparts (due to the shorter JDM cat), but this is the first time I'm reading about a different sized flange.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
Are you certain of this? I'm aware that "JDM-length" exhausts differ in overall length compared to their USDM counterparts (due to the shorter JDM cat), but this is the first time I'm reading about a different sized flange.</TD></TR></TABLE>
I am positive on this. I installed a Mugen twin loop from a JDM ITR on my '97 GSR. WHen I had a DC sports 4-2-1 and the stock catalytic converter, I had to modify the connection to the Mugen cat-back. Now that I have a JDM ITR catalytic converter, it is a direct fit. King Motorsports would reflange these exhaust systems to make them fit the USDM catalytic converters.
This all makes sense because the JDM ITR collectors are larger than the USDM as well.
Post a pics of the MUGEN once you get it mounted up, Bro! SICK!
axle back wont bolt on to ur stock LS, i had an axle back mugen on my car, and the flange is a 2.5 collector so bigger then stock. then got a stock ITR axle back, and had to get the flange re-done back to 2.5 collector
Boostless-Lude
Oct 17, 2007 05:55 AM
itr98spec
Apr 23, 2004 03:37 PM
