FS Drop in H22 swap for EK from HMO. Complete with everything. Works for EG/DC also.
FS: H22A complete swap for 96-00 civic. Comes with the following. 55-65k on engine/trans.
-JDM obd1 h22a complete motor from HMO. 195-200psi on all cylinders.
-innovative EK mounts (have a set of eg/dc mounts too but they are cheapo type)
-jdm h22 trans
-oem axle combination
-fidanza flywheel and what I think is an exedy clutch
-manual tensioner conversion
-shifter cables and accord shifter
-jdm obd1 p13 mt ecu
-ngk blue wires with ngk iridium plugs
-obd2a to obd1 conversion harness
-96-98 engine harness with all wiring converted and resistor box included.
Basically that's everything. It is plug and play for 96-98 civics, and with the other mounts and simple wiring its plug and play for eg/dc as well. 99-00 civics and 99-01 tegs would need a different obd conversion harness and engine harness but thats all.
Asking $2k OBO, willing to nego, especially if you have a d16y7/y8 swap to trade me for it.
Price it out and you'd be in well over that trying to collect all the small parts
Located in Northern Utah. Willing to ship at buyers expense (around $300). Paypal accepted and willing to split the fees 1.5% each, prefer money order to avoid fees.
Many vouches here online and many can vouch for the motor itself. Pulls great. All basic maintenance performed including timing belt and water pump. The balance shaft tensioner is a bit squeaky but I was just gonna eliminate the balance shafts so I never bothered replacing it.
Pm me with any questions or for contact info.
Thanks for reading
-jdm h22 trans
Thanks for reading
