CRUNCH in 2nd gear!
Old Sep 18, 2007 | 04:57 AM
Flip's DC5's Avatar
Default I need a K tranny GURU!
When I'm shifting up into 2nd gear, I feel a grind in the gear eventhough my foot is all the way down on the clutch. it doesn't happen for any other gear, not even when I'm downshifting into 2nd. I did notice that if I let the rpm's go down then sift it into 2nd, it doesn't happen. I dont' think my clutch is wearing out since it's only happens at 2nd gear but I'd hate to hear the news that my 2nd gear is going out. Please help! I'm new to K's and HT. Thanks for any kind of positive help. This forum has helped me get to know my car more.
Modified by Flip's DC5 at 7:36 AM 9/18/2007
Old Sep 18, 2007 | 06:55 AM
WhiteOnRice's Avatar
The synchro is going bad. Does it do it if you shift (up) into second at the exact rpm it should be at when the clutch is out?
Old Sep 18, 2007 | 07:09 AM
Flip's DC5's Avatar
Default Re: (WhiteOnRice)
Yeah it does. I'm gonna go and drive it around during my lucnh break just to make sure and I'll let you know. Thanks!
Old Sep 18, 2007 | 07:42 AM
mucter's Avatar
2nd gear is notoriously weak on the DC5. There was a TSB for it from Honda.
Old Sep 18, 2007 | 09:28 AM
1986's Avatar
Default Re: I need a K tranny GURU! (Flip's DC5)
check out the 2nd gear grind petition on clubrsx. Its a common problem, and its something most of us are going to have to live with because its going to be hard to get warrenty work out of acura. Your probably gonna notice a 3rd gear wall, and ocasional popouts also. At first it bothered me, but now i am used to it i am just gonna live with it.
Old Sep 18, 2007 | 09:40 AM
02whiteDC5's Avatar
Default Re: I need a K tranny GURU! (1986)
I have the same problem.. maybe worse. To shift from 1st to 2nd I have to use an incredible amount of muscle.. from 2nd to 3rd, It would simply not shift.. I had to let the car roll a lil the force 2nd gear out then into 3rd.
I took it to the dealership yesterday and Im wating to see if the warranty covers it. I only have 2 months with the car, so hopefully they will fix it under the warranty.
good look with your situation, I let you guys know how mine ends up.
Old Sep 18, 2007 | 10:37 AM
Flip's DC5's Avatar
SInce it's a common problem, does it mean that it's an issue that can be ignored or does that mean that I go ahead and just baby 2nd gear and apparently 3rd as well? I'd hate to ignore the issue then have my tranny fall out when I shift into 2nd. Thena gain at the same time, i'd hate to be worried about it when there's nothing to worry about. I tried reading up on the issue at ClubRSX but all they had to say was the fact that all of them had that problem. THANKS FOR ALL OF THE HELP. Now that I know I'm not the only one with the problem, I can feel more comfortable with driving it.
Old Sep 18, 2007 | 11:34 AM
T_Virus's Avatar
Have you change the tranny fluid yet? It is not going to fully fix the problem but change the tranny fluid.
Old Sep 18, 2007 | 12:47 PM
Master23's Avatar
Same thing happening to me. Normal for DC5 transmission.
Old Sep 18, 2007 | 01:20 PM
951dc5's Avatar
since this is a common problem for the dc5. i'm gonna have to be easy on mine. warranty is void and tranny repair is a b****.
Old Sep 18, 2007 | 01:41 PM
1986's Avatar
For real though, change your tranny fluid. It helps a bit. Personally I suggest gm synchomesh or amsoil mtf. But theres others, just do some research
Old Sep 18, 2007 | 05:38 PM
joey funk's Avatar
yea mines the same way in my ep3 but its 3rd gear. it really blows, everyone thinks i miss shift or something, Embarasing
Old Sep 19, 2007 | 01:09 AM
nahonda04's Avatar
Surje.motorsports
yea i have the same problem in my 02 em2, 3rd gear grinds if i push past 4k, its sux ***, i have changed my tranny fluid twice and it still happens, hondas in general are notorius for bad sychros in 2nd and 3rd gear. get used to it or get it fixed!
Old Sep 19, 2007 | 01:12 PM
02whiteDC5's Avatar
Default Re: (nahonda04)
Hopefully you get a nice solution for yours. I took mine into the dealership monday and they just call me today to put me on a 22 situation. check this out:
- the diagnostic (how ever you spell it) says there is a transmission problem, but it needs to be taken apart to figure out what exactly is. If is covered by the warranty, I dont have to pay a cent.
-By taking the tranny out of the car, Im looking at $440 dollars in labor if the warranty dont cover whatever is wrong with it.
- The only way to find out if im covered or not is "gambling" $440 dollars out of my poket or $1,200 to completly fix it.
well, thats what they have told me so far. I told them to go ahead and take the tranny apart to check it, if Im not covered, well... pay the $440 and take mi car out of there in a tow truck. fix it when I get the money.
sorry for jacking your post, But I think it might be helpfull for others with this problem.
Old Sep 19, 2007 | 06:06 PM
Flip's DC5's Avatar
Default Re: (02whiteDC5)
^^Bro that sucks man. I'd hate to go to the dealership and have them tell me the same thing...I just bought the damn thing!
Old Sep 19, 2007 | 08:47 PM
simonEp3's Avatar
I have the same problem in mine with 2nd to. Also, I was coming back from Nashville about 2 months ago and I was cruising down the interstate when my car kicked itself out of 5th gear. My friend has been having the same issues with his tranny.
Old Sep 19, 2007 | 09:37 PM
k-money's Avatar
wasn't the second gear grind a defection on the 02 models?
Old Sep 20, 2007 | 06:35 PM
Tyte-S's Avatar
Default Re: (k-money)
I think the 02's are the worse. I drove my friends '05 and i didnt notice it as much, tho it was a little notchy. Just something we're all gonna have to learn to live with, cuz even when i shift slow as all hell, it still show a little resistance.
Old Sep 20, 2007 | 06:37 PM
Tyte-S's Avatar
RECALLLLLLLLLLLL We should all set a date and everyone with a dc5 or an eps go down to their local honda dealership and let em know that we're not happy about it. IMO.
Old Sep 21, 2007 | 05:38 AM
Flip's DC5's Avatar
Default Re: I need a K tranny GURU! (Tyte-S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyte-S &raquo;</TD></TR><TR><TD CLASS="quote">RECALLLLLLLLLLLL We should all set a date and everyone with a dc5 or an eps go down to their local honda dealership and let em know that we're not happy about it. IMO.</TD></TR></TABLE>
Hell yeah man! I'm all for it! I'm sure that everyone else who agrees with me
Old Sep 21, 2007 | 08:51 AM
I have an 02 ep3 with 57,000 miles and no grinds at all.... yet.
Old Sep 21, 2007 | 09:27 AM
Flip's DC5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice &raquo;</TD></TR><TR><TD CLASS="quote">I have an 02 ep3 with 57,000 miles and no grinds at all.... yet.</TD></TR></TABLE>
Damn you!
Old Sep 21, 2007 | 09:35 AM
1986's Avatar
ive herd of people changing their tranny fluid to synthetic-based early before they experience any grind issues. and their transmissions seem to be fine. Early as in like when the car only has 5k on it.
Old Sep 21, 2007 | 11:24 AM
pcorad's Avatar
Default Re: (Tyte-S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyte-S &raquo;</TD></TR><TR><TD CLASS="quote">I think the 02's are the worse. I drove my friends '05 and i didnt notice it as much, tho it was a little notchy. Just something we're all gonna have to learn to live with, cuz even when i shift slow as all hell, it still show a little resistance.</TD></TR></TABLE>
02 with 116,000 miles. No crunching. When it's cold out, it can be a little notchy. But it warms up and is fine.
I do question the clutch... I never really have liked it. The full engagement seems to occur in about 1" out of 7" of travel.
Old Sep 21, 2007 | 07:16 PM
02whiteDC5's Avatar
well, my problems were all solved.... I think you guys should try the same (if you have warranty).
Dealership called me yesterday to tell me its all set, they will replace 1st, 2nd and all the sychros (something call gear set) for only $100 dollars deductible. not bad at all for a brand new tranny (almost).
they said they found somenting wering out inside the tranny and that with the time just got worse, so they are replacing everything.
good look, and I think you should take it to the Dealership to see if it works out for you.
