FS: GSR JRSC LHT, Head, CAMS, MOUNTS, HONDATA, ARP, Innovate, Valvecover LS/VTEC, ACTION
PICS ARE HERE CLICK THIS
I had a huge plan to make approx 275 WHP with a fun to drive and VERY streetable power band.
Please PM me with any questions. Dibs are to be called in the thread.
HONDATA S300 in P28 $650 SHIPPED Hondata S300 used on the car for a couple months. Tested and working great. Now that I've used S300 I wouldn't buy anything else.
RX-7 oil cooler $100 All Aluminum 2pass Oil cooler with no cracks, Comes with -10AN fittings. Was going to use this for the heat exchanger. I have over $150 into this setup. These fittings are expensive and took 2 WEEKS from Jegs.
JRSC fuel pressure regulator indexing adapter $40 This allows you to turn your regulator moving the return line out of the way of the JRSC manifold
Valve Cover $100 Valve cover is metallic black, Has ONE -10AN fitting welded on the front for catch can setup. VTEC is larger than DOHC.
LS/VTEC Oil Line $60 -4AN feed line from block to head. Tee for back of block where low oil light sensor is.
LS head gasket $65 Brand new from acuraautomotiveparts.com 12251-PR4-004 For LS/VTEC or LS
Greddy Catch Can $60 Greddy, Baller **** what more can I say.
GSR Head $OLD
GSR Cams $OLD
LHT manifold SOLD
JRSC for GSR or B16/ITR.SOLD
Action 2KS Clutch $SOLD
Modified by MADEINIRAQ at 8:00 AM 12/14/2007
GSR Head $OLD
GSR Cams $OLD
LHT manifold SOLD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR615 »</TD></TR><TR><TD CLASS="quote">&M fuel pressure regulator w/ 90degree FPR $40 Black - Probably need this for the JRSC so the return line clears the LHT manifold.
pixx</TD></TR></TABLE>
http://lh6.google.com/mikepigg...x=640
