clutch pedal bracket
Old Sep 18, 2007 | 01:39 AM
zurud's Avatar
Default clutch pedal bracket
My clutch pedal bracket broke again. This is the second time it happen. The first time it broke on the right side of the pin and I had my dad weld it. Now the pin itself on the left side broke. Should I buy a new bracket or just weld it again hoping it won't break anymore? Is the pedal bracket pn 86694?
Old Nov 1, 2007 | 08:34 PM
jwykle's Avatar
Default Re: clutch pedal bracket (zurud)
I'm having the same problem on my 91 DX, How big of a pain are they to get out?
Old Nov 1, 2007 | 09:13 PM
EFh@tCh24's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zurud &raquo;</TD></TR><TR><TD CLASS="quote">My clutch pedal bracket broke again. This is the second time it happen. The first time it broke on the right side of the pin and I had my dad weld it. Now the pin itself on the left side broke. Should I buy a new bracket or just weld it again hoping it won't break anymore? Is the pedal bracket pn 86694?</TD></TR></TABLE>
ahhhhhh ahhahahah damn i had the same problem on my hatch watever u do do not use a crx bracket i thot it wud work but for sum reason it sticks out....i think its better if you go pull one off the junk yard it shouldnt cost that much....
Old Nov 1, 2007 | 09:48 PM
jwykle's Avatar
Default Re: clutch pedal bracket (EFh@tCh24)
I've heard an integra one is the same? True or false? Let me know before I waste money.....
Old Nov 2, 2007 | 06:58 AM
CRX Toad's Avatar
Default Re: clutch pedal bracket (jwykle)
I have compared them side to side and it does not appear to be the same. I do know that the CRX Si clutch bracket is a little beefier and has an addition support. Might be something to look into.
Old Nov 2, 2007 | 08:58 AM
abnaasefmb's Avatar
Default Re: clutch pedal bracket (CRX Toad)
Just weld it and consider it stress relived. What clutch are you using? I use a clutch master fx300 and have never had a problem. Some pressure plates are very harsh. Using a good compound on the clutch will make a huge difference and allow a softer pressure plate. I have 280hp again with no trouble.
Old Nov 2, 2007 | 09:04 AM
Hanmin's Avatar
I just replaced mines, it was a pain in the ***, took me 6 hours but I didn't have all the tools I needed so I had to improvise a lot. I'm 100% sure all of the ef's/crx's pedal brackets are interchangeable.
Old Nov 2, 2007 | 09:15 AM
jwykle's Avatar
I took the seat out to have more room to lie under the dash. Going to drop the stearing column in a few. I've heard diff assemblys will work, I've heard they won't... who knows...
Old Nov 2, 2007 | 09:24 AM
Hanmin's Avatar
steering column is only 6 nuts/bolts. It works, I used a wagons assembly in my hatch. Your gonna have to remove the heating vents if you dont have wrench's. And a little hint when taking the assembly off, you need somebody go in the hood and pull the circle brake thing that connects to the pedal back so the assembly can come out because it blocks it a little.
Old Nov 2, 2007 | 10:51 PM
EFh@tCh24's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">I have compared them side to side and it does not appear to be the same. I do know that the CRX Si clutch bracket is a little beefier and has an addition support. Might be something to look into. </TD></TR></TABLE>
the si does have a lil more support but i it does not bolt on with all of its bolt trust me that what i have on right now....i would say it would be better to find the same one in the junk yard.....most of them look all the same but dont trust it to fit
Old Nov 3, 2007 | 11:46 AM
jwykle's Avatar
I've heard that the 90-93 integra is the same.. From what I've seen they are.. Can't hurt to try. Anymore feedback on this idea?
cl9 jon
Jul 21, 2014 04:14 AM
fastshift
Welding / Fabrication
21
Mar 6, 2008 09:58 AM
syntax.
Jul 14, 2006 10:03 AM
Gant
Mar 20, 2005 01:43 PM
[626]95-GSR
11
Mar 29, 2003 09:13 PM
