eibach, OEM parts, wheels, b16a engine parts/blocks ETC.
Old Sep 17, 2007 | 11:47 PM
suicide_shift's Avatar
* B A N N E D *
Default eibach, OEM parts, wheels, b16a engine parts/blocks ETC.
ALL PRICES OBO
-eibach springs
sportlines
just the springs
for the 01-05 civic chassis
$65
-b16a jdm obd1 engine block
comes with crank,oil pan, and few other parts
i belive its from an integra xsi the 5 in the serial number designates it
-rear trailing arms
ef chasis
rear drums
missing 2 brake hardlines
$15
-k series power steering pump
$50
-b16a intake mani with fuel injjectors
includes throttle body
$25
-d16y7 head bare
$30
-p2p ecu
manual trans
$20
-jdm wakaba badges all 3 types
$10 each
-pr4 ecu
green/black plug so OBD0
$20
greddy cast iron turbo manifold d16z6, t25 flanged.
220 obo
-cruise control actuator? its the black box that is bolted to the shock tower under the hood -$ 10
-d16z6(ex sohc vtec) automatic trans with tq converter and flex plate w/ bolts if you need it -200
-power steering pump with pulley, with resivoir and lines also the bracket to hold the system to the block $ 50
-ac compressor condensor, mounts, black mount and bolts, lines, dryer, belt $80
-rear trailing arms from an eg, no ABS, rear drum brakes (the actual trailing arm is a universal pieace you can remove the drum part and bolt a disc to it.-$65
- 30/30 prop valve (non abs rear drum civic 92-95 brake proportioning valve) $10
i have other **** for sale too i just cant think of it, if you need something just ask.
trades? -sure
location riverside county, all over the county
Modified by suicide_shift at 11:49 PM 10/27/2007
Old Sep 18, 2007 | 09:51 PM
* B A N N E D *
Default Re: eibach, OEM parts, wheels, b16a engine parts/blocks ETC. (suicide_shift)
trade for.......................e-6010 reverse plarity welding rod. lots of it
Old Sep 19, 2007 | 03:50 PM
* B A N N E D *
leaving for school bump
Old Sep 19, 2007 | 08:54 PM
* B A N N E D *
BBBBBBBBBBB.......UUU..........UUU....MMM......... .......MMM.....PPPPPPPPP
BBBBBBBBBBBB.....UUU..........UUU....MMMM......... ...MMMM.....PPPPPPPPPPP
BB..............BBB.....UUU..........UUU....MMMMM. .......MMMMM.....PPPP......PPPP
BB.............BB........UUU..........UUU....MM... MMM..MMM...MM.....PPPP......PPP
BBBBBBBBBB.........UUU..........UUU....MM....MMMMM M....MM.....PPPPPPPPP
BB.............BB........UUU..........UUU....MM... ...MMMM......MM......PPP
BB.............BBB......UUUU......UUUU....MM...... ...............MM......PPP
BBBBBBBBBBBB......UUUUUUUUUU.....MM............... ......MM......PPP
BBBBBBBBBBB.........UUUUUUUUU....MMMM............. ...MMMM...PPPPP
Old Sep 20, 2007 | 11:03 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suicide_shift &raquo;</TD></TR><TR><TD CLASS="quote">BBBBBBBBBBB.......UUU..........UUU.. ..MMM................MMM.....PPPPPPPPP
BBBBBBBBBBB.........UUUUUUUUU....MMMM............. ...MMMM...PPPPP</TD></TR></TABLE>
Old Sep 22, 2007 | 01:51 AM
* B A N N E D *
Old Sep 22, 2007 | 09:44 AM
OmGitsKINNY's Avatar
BUMP
Old Sep 22, 2007 | 07:43 PM
* B A N N E D *
Default Re: eibach, OEM parts, wheels, b16a engine parts/blocks ETC. (OmGitsKINNY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OmGitsKINNY &raquo;</TD></TR><TR><TD CLASS="quote">BUMP </TD></TR></TABLE>
Old Sep 23, 2007 | 09:01 PM
* B A N N E D *
Old Sep 23, 2007 | 09:48 PM
* B A N N E D *
Old Sep 23, 2007 | 09:56 PM
y0whuddupb's Avatar
you got an idle air control valve (iacv) and b-series vtec solenoid?
Old Sep 24, 2007 | 02:38 PM
* B A N N E D *
Default Re: eibach, OEM parts, wheels, b16a engine parts/blocks ETC. (y0whuddupb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y0whuddupb &raquo;</TD></TR><TR><TD CLASS="quote">you got an idle air control valve (iacv) and b-series vtec solenoid?</TD></TR></TABLE>
neither sorry
Old Sep 25, 2007 | 11:38 AM
* B A N N E D *
Old Sep 25, 2007 | 11:41 AM
em1si5853's Avatar
bump!
* B A N N E D *
Default Re: eibach, OEM parts, wheels, b16a engine parts/blocks ETC. (em1si5853)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1si5853 &raquo;</TD></TR><TR><TD CLASS="quote">bump!</TD></TR></TABLE>
pm'd
Old Sep 26, 2007 | 12:44 PM
* B A N N E D *
Old Sep 26, 2007 | 01:04 PM
* B A N N E D *
added new parts bump
Old Sep 26, 2007 | 10:12 PM
* B A N N E D *
Old Sep 27, 2007 | 12:01 PM
* B A N N E D *
bump
Old Sep 27, 2007 | 09:54 PM
* B A N N E D *
Old Sep 28, 2007 | 10:46 PM
* B A N N E D *
Old Sep 29, 2007 | 05:40 PM
* B A N N E D *
bump
Old Oct 1, 2007 | 10:30 PM
* B A N N E D *
bump
Old Oct 2, 2007 | 12:20 PM
* B A N N E D *
Old Oct 4, 2007 | 11:05 PM
* B A N N E D *
