buddy club spec III cams or spec iv
Old Sep 17, 2007 | 09:26 PM
M36's Avatar
M36
Default buddy club spec III cams or spec iv
trying to figure out what spec 3 or 4 would be better to go with.
I have a B18c, 11.3 cr, itr valve springs, jdm itr ecu 9k redline.
I know the spec spec III would do alright with this setup.
But I was not sure about the spec IV. I am sure I would need Ti valve retainers and probley valve springs. I have not been able to find much info on the spec iv. Do they idle ok? Do they need more fuel? any info would be great.
also, I've seen the BC Spec III seem to reach peak HP at about 8k rpm. What do the Spec IV reach peak HP at?
Modified by M36 at 10:42 PM 9/17/2007
Old Sep 17, 2007 | 11:41 PM
oldskool teggy's Avatar
Default Re: buddy club spec III cams or spec iv (M36)
run the bc3
Old Sep 18, 2007 | 12:57 AM
cartune network's Avatar
Default Re: buddy club spec III cams or spec iv (oldskool teggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oldskool teggy &raquo;</TD></TR><TR><TD CLASS="quote">run the bc3</TD></TR></TABLE>
go with the bc3's the 4's would be better if u had a higher comp ratio but the 3's are good for 11.0:1
Old Sep 18, 2007 | 01:09 AM
Chris Tune's Avatar
Default Re: buddy club spec III cams or spec iv (cartune network)
the bc4's work good on 11's he's valve spring cant take them thou...
Old Sep 18, 2007 | 03:43 PM
M36's Avatar
M36
thanks guys. I'm going go with buddy club spec III.
Old Jan 26, 2008 | 02:12 PM
Spoon_Si-R's Avatar
I'm actually in the market for some BC3+ cams as well. Can these cams make power past 8K? Would ITR valves springs/ret suffice? And its going on a B16A2 head.
Old Jan 27, 2008 | 07:46 AM
Spoon_Si-R's Avatar
bump
Old Jan 27, 2008 | 08:34 AM
ekBlackHatch's Avatar
Default Re: (Spoon_Si-R)
i belieave they make most there power to 8k after that they start to fall off the 4's make power to 9k but require a lil more mods
Old Jan 27, 2008 | 09:46 PM
b18c5 EG's Avatar
buddy club spec 3's have a good mid range and usually stop making power around 8500 in my experience with them...i noticed a huge difference driving around town even untuned
Old Jan 27, 2008 | 11:29 PM
B20 Civic's Avatar
Default Re: (1SloSol)
Sorry to hi-jack but I'm running a B20 VTEC with 10.8 compression and all the usual bolt-on's and head work with a set of BC IV cams planning to rev to 8500 rpm. Will these be OK or do I have to change cams?
Old Jan 27, 2008 | 11:47 PM
b18c5 EG's Avatar
honestly spec 4's might be too big for your mild set up......i would go with spec 3 for a reliable street car which would see some good gains but thats just my opinion
Old Jan 28, 2008 | 09:48 PM
B20 Civic's Avatar
Any other cams you will suggest with that compression???
Old Jan 29, 2008 | 03:45 AM
2000EK4's Avatar
Default Re: (B20 Civic)
BC3 vs BC4 on B18C
BC3 vs BC4 on B20
I had the BC3:s in my B16.Loved em.
Now that i am getting a B18C5 i whent with the 4:s.
Old Jan 29, 2008 | 06:00 AM
B20 Civic's Avatar
Default Re: (2000EK4)
What compression are you running?
Old Feb 4, 2008 | 09:34 PM
integratee's Avatar
i have the BC III+ they worked good for me. if you guys are looking for a set of III+ or V specs hit up: myfirstdc2 he has some custom cams ground and guaranteed by Skunk2 themselves and they are ALOT cheaper than buying the actual Buddy Club cams. Same exact specs and everything. just thought id throw it up here to save some of you some cash if getting cams. $375 picked up and 1yr (i think) guarantee by Skunk2.
Old Feb 4, 2008 | 09:43 PM
Ass$nyper's Avatar
Pirate General...YARRRR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000EK4 &raquo;</TD></TR><TR><TD CLASS="quote">BC3 vs BC4 on B18C
.</TD></TR></TABLE>
More details on this motor please, it looks like the 4s are just flat making more power all around here.
Old Feb 4, 2008 | 10:42 PM
Fat Chick Magnet's Avatar
vtec killer cams.
Old Feb 12, 2008 | 05:18 PM
-=Zeqs=-'s Avatar
Default Re: (Fat Chick Magnet)
This is my old dyno sheet from about three years ago. That is on BC3+, JDM B18C, JDM ITR header, Password JDM Whale's *****, Hondata S100 tuned by Elton @ Raceline, Carsound 2.5" Highflow cat, with 2.5" mandrel piping exhaust.
Old Aug 26, 2009 | 03:19 PM
battlebornimports's Avatar
TO RUN THE BC SPEC4 DO YOU NEED TO RUN THERE VALVE TRAIN ALSO
Old Aug 26, 2009 | 06:48 PM
OH_1fstgsr's Avatar
I think in either case you are going to be spending more money than just new cams. Larger injectors and a programable ECU are going to be a must. If you go with the BC4 more money on springs and retainers.
Go with the BC3+, programable ECU, injectors and get it tuned.
Old Aug 26, 2009 | 08:41 PM
patriot's Avatar
Way to bump an OLLLLLD thread...
...and no, you don't have to use THEIR valve train...just don't use stock either.
Old Sep 1, 2009 | 12:36 AM
honda-will's Avatar
ya, you could atleast bump it with useful information. ecu, injectors would be a waste of time and money. spec3s are buddy club entry level cams. no valve springs needed. no tunning needed. just put them in there. (kinda like getting type r cams)
Old Sep 1, 2009 | 04:05 AM
patriot's Avatar
atleast i know a tune isnt a waste of time or money
Old Sep 1, 2009 | 08:18 PM
honda-will's Avatar
shows what you know.
Old Sep 2, 2009 | 03:46 AM
patriot's Avatar
lol
