need help car wont go pass 7 grand
ok recently the screw came out of my rotor in my distributer and went into my ignition control moduel. since then it won't go pass 7000. there has been a couple times i have gone pass 7000 but it kinda studdered. the rpm slowed down and it wasn't smooth. i have a rs with a gsr motor swap. it has a p28 with a hondata s300. some people said they thought it was my ecu but i can change everything.i have changed the vtec just to make sure. dnot know what to do any help
then maybe it would cause it at highR rpms. cuz its important that the screw is there!
it will mess with your timing too
does the car seam to hit a rev limiter or does it just have a hard time going past 7k? Studdering, bogging, etc.. How long has it been doing this? Checked ur oil recently? sometimes the cel won't come on but if ur oil gets low enough it'l have a hard time building up enough pressure.
so it hits an actal rev limiter at 7k? has it always done this? yeah check ur oil, check ur ecu ground too, i had this problem once when my ecu ground was loose. Grounds let u know they're loose when u put a heavy load on them and they can't take it.
apaige58
10
Aug 5, 2013 04:36 PM
mashed_potatos
Mar 18, 2010 12:54 PM
confucius
Mar 8, 2005 07:26 PM
voltronR34
11
Nov 15, 2002 10:16 PM
