Help my accord is dieing
Old Sep 17, 2007 | 05:01 PM
russlan44's Avatar
Default Help my accord is dieing
I have a 98 accord V6 auto, and it has 154.XXX while driving it dies, going at speed then all the suddent the car doesnt accelarate, you give gas the RPM's are still dropping and when you come to a complete stop the car stalls and you have to wait for 1 min or 2 so ill start again. need help have no idea what it is, its not trowing Check Engine light ether.
Old Sep 17, 2007 | 07:49 PM
russlan44's Avatar
Default Re: Help my accord is dieing (russlan44)
evening bump before i go home
Old Sep 18, 2007 | 12:16 AM
Mangotreemechanic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by russlan44 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 98 accord V6 auto, and it has 154.XXX while driving it dies, going at speed then all the suddent the car doesnt accelarate, you give gas the RPM's are still dropping and when you come to a complete stop the car stalls and you have to wait for 1 min or 2 so ill start again. need help have no idea what it is, its not trowing Check Engine light ether.</TD></TR></TABLE>
Seems electrical power is lost, then regained. So it could be your main relay or else your ignition switch. Need more info, but this is a place to start. Sometimes, an intermittently defective (dying) coil will cut out, but regain operability. Good luck. Let us know what happens next.
Old Sep 18, 2007 | 01:42 AM
cartune network's Avatar
Default Re: Help my accord is dieing (Mangotreemechanic)
this happened to me with my 97 lx 4cyl automatic lol i looked through everything in the car and it turned out that there was a hairline crack going through the distributor and when it would get cold out the motor would stall cause the crack would get bigger in the cold weather. o yea moisture was a bitch too.
Old Sep 18, 2007 | 11:41 AM
russlan44's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mangotreemechanic &raquo;</TD></TR><TR><TD CLASS="quote">
Seems electrical power is lost, then regained. So it could be your main relay or else your ignition switch. Need more info, but this is a place to start. Sometimes, an intermittently defective (dying) coil will cut out, but regain operability. Good luck. Let us know what happens next. </TD></TR></TABLE>
My 98 prelude had ignition switch problem, that it was dieing, but didnt thought ill be on accord to aldo they are the same year, after i changed my ignition switch on prelude it was fine and didnt stall, some told me it could be a coil. does any one has a picture of where the coil located on v6 accord, i berly know anything about that car its my wifes car and i never touch it.
Old Sep 18, 2007 | 07:04 PM
a.wax's Avatar
this same thing happened to my friends 98 accord lx. His engine shuts off and his steering wheel locks. I guess this is a common? I'm not sure, but willing to find out as well so you and my friend gets this fixed..
Old Sep 18, 2007 | 07:32 PM
russlan44's Avatar
Default Re: Help my accord is dieing (a.wax)
yep sounds like same thing, i dont let my wife drive her car anymore cuz of that, stering wheel locks
Old Sep 21, 2007 | 03:14 PM
1996accordex's Avatar
my 96 accord was great the first two years i had it, but then it started acting funny
sometimes when im at a stop light for a little while and then when i hit the gas to go, it starts to go but struggles for a second or two then runs fine until the next stop and it repeats, it happens about 1 out of every 10 stops . sometimes more. Any thoughts would be much appreciated.
Thank You
Old Sep 21, 2007 | 03:18 PM
Honda-Master's Avatar
there is a recall on 98 accords ignition switch,,,,, have you had it done ??
Old Sep 21, 2007 | 04:53 PM
russlan44's Avatar
Default Re: Help my accord is dieing (Honda-Master)
nope i havent done it, car is salvage title so i know dealer wont do **** for sense it doesnt have clean title. but tx ill look into it, i had same problem with my 98 prelude it was ignition switch
Desiss
Dec 23, 2007 04:16 PM
aleck
Nov 1, 2005 02:31 PM
