putting a d15b8 into a 91 STD?
Old Sep 17, 2007 | 04:29 PM
pythoner's Avatar
Default putting a d15b8 into a 91 STD?
what do I have to change to put the d15b8 inplace of the d15b1 besides the intake mani, altenator, exhaust?
Is the d15b8 dizzy the same bolting patten as the stock motor? I know that the d15b8 is OBD1 and the car is OBD0 so I need to find a dizzy that will work.
THanks
Stephen
Old Sep 18, 2007 | 03:00 PM
pythoner's Avatar
I would like this answer from some EF guys....I am trying to help someone else
Old Sep 18, 2007 | 04:11 PM
VtecSyndrome's Avatar
Default Re: (pythoner)
Isn't the d15B8 an 8 valve motor?? I am pretty sure it is and if so I hope your just using the block cause that head SUCKS not too mention the pistons only have 2 valve reliefs ea due only having 8 valves. I am pretty sure you can still use the block w/ a 16 valve head but I don't know how close the valves will sit to the piston.
Old Sep 18, 2007 | 06:11 PM
obd1_crx's Avatar
some B8's have the extra valve reliefs. ive got a 93 B8 and it has all 4 in each piston. i think in 93 they started using the same pistons as the B7 just different heads.
Old Sep 19, 2007 | 01:49 AM
pythoner's Avatar
not 100% sure but I thiink it has the 16 relifes...I just need to know if the dizzy will bolt up...a guy at work needs better milage he drives nearly 200 miles a day and is getting 38~mpg...I am also looking to get a HF trans for him thou
Old Sep 19, 2007 | 04:04 AM
pythoner's Avatar
does anyone know what OBD0 dizzy will bolt up to a d15b8? I need at least 2 of the 3 ears to attach
Old Sep 19, 2007 | 07:06 AM
290allen's Avatar
yes it will bolt up, all three holes, have a b8 in my parts car
Old Sep 19, 2007 | 12:55 PM
pythoner's Avatar
thanks...you just got me paid!
eg-asaurus
Dec 17, 2011 08:13 AM
black97civic
14
May 5, 2011 09:48 AM
jdmeg6bswap
May 20, 2010 09:09 AM
obd1_crx
Jun 12, 2007 05:32 PM
