Obd0-obd1 conversion parts...
Old Sep 17, 2007 | 03:55 PM
denraweb's Avatar
Default Obd0-obd1 conversion parts...
Ok, I'm saying screw the harness, I'm gonna just make one...(Yes I will be soldering and shrink tubing)...but I have a question about the distributor...
Since I am running a b16 (DOHC Vtec) shouldn't I use an obd1 DOHC Vtec distributor, from, let's say, a GSR or a Del Sol Vtec?
I have heard people say that a single cam VTec distributor will work? Is this true, or not?
Also about the 4-wire o2 sensor...what header, besides del sol (hard to find sometimes) can I used? I know like gsr and ls headers are different (ls is longer, I think). Can I also drill and tap a hole in the stock b16 header to add the 4-wire o2 sensor?
Old Sep 17, 2007 | 05:00 PM
Crx Jimmy's Avatar
Default Re: Obd0-obd1 conversion parts... (denraweb)
yes you want to use a obd1 b16 or gsr dizzy. and you can use a del sol, or ls header they are the same length. the gsr is shorter and doesnt have a o2 hole in it at all(they had them in the cat)
Old Sep 18, 2007 | 12:22 AM
denraweb's Avatar
Default Re: Obd0-obd1 conversion parts... (Crx Jimmy)
So does that mean I have to use a del sol or integra ls mid pipe? Or is that header the same as the jdm b16 header??
One other thing too, does anyone know if there are any other intake manifolds to use besides the del sol VTec or skunk2 obd1 manifolds to do state ref in california?
Old Sep 18, 2007 | 06:39 PM
denraweb's Avatar
bump
Old Sep 20, 2007 | 12:16 AM
denraweb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by denraweb &raquo;</TD></TR><TR><TD CLASS="quote">So does that mean I have to use a del sol or integra ls mid pipe? Or is that header the same as the jdm b16 header??
One other thing too, does anyone know if there are any other intake manifolds to use besides the del sol VTec or skunk2 obd1 manifolds to do state ref in california?</TD></TR></TABLE>
ttt
Old Sep 20, 2007 | 10:34 PM
denraweb's Avatar
biglebowskicivic
Oct 27, 2003 07:53 PM
othick
Mar 25, 2003 03:51 AM
prjctCIVIC
Mar 19, 2002 08:04 PM
