pic's of my set up
Old Sep 17, 2007 | 03:09 PM
ef8_eg6's Avatar
Default pic's of my set up
couple pic's of the progress..charge pipes went out to power coat so there no pics of those..but injoy..feed back ould be nice
http://i142.photobucket.com/al...r.jpg
Old Sep 17, 2007 | 03:16 PM
Type-ARR's Avatar
Nice set up.
Old Sep 17, 2007 | 03:46 PM
civicsi940's Avatar
whats the setup? nice thus far. i think it was you or someone else i read a couple days ago who got a manifold done like that if i remember correctly and posted it in the SOHC boosted thread.
Old Sep 17, 2007 | 03:47 PM
blwn95civic's Avatar
Default Re: (Type-ARR)
is that the stock manifold with a pipe to convert it to a turbo manifold??
Old Sep 17, 2007 | 03:55 PM
ef8_eg6's Avatar
Default Re: (trav95civic)
its a d16z6
t3 turbo
arp head studs
msd ignitoin
jdm sport innercooler
3inch down pipe
deltagate watgate
greddy bov
hondatas300
f1 stage 4 clutch
cosmetic head gasket
e cutout
the manifold is a dual zc top ported..the down pipe was taking off and a custom one was made to fit a t3 flange
Old Sep 17, 2007 | 03:59 PM
Default Re: (ef8_eg6)
thats pretty neat, id like to see how that setup does.... its a hella cheaper way of boosting without throwin money for a manifold(if it works out good)
Old Sep 17, 2007 | 04:04 PM
ef8_eg6's Avatar
should work perfect..my buddy has the same set up jsut with a bigger turbo since his is built motor..and hasnt dyned that i know of but should be in the 400 hp range
Old Sep 17, 2007 | 04:16 PM
EASY101's Avatar
* B A N N E D *
nice way to budget build...i wonder how good it works ?
Old Sep 17, 2007 | 04:27 PM
1cpu's Avatar
yea thats a nice setup there, keep us posted.
Old Sep 17, 2007 | 04:35 PM
blackeg's Avatar
Default Re: (1cpu)
looks good. be careful of boost spike/creep with that deltagate
Old Sep 17, 2007 | 04:45 PM
ef8_eg6's Avatar
Default Re: (blackeg)
they told me that about that wastegate..if i noticed something diffrent i'll be changing to tial.
Old Sep 17, 2007 | 07:52 PM
soulpwr's Avatar
The Dyno will tell you how well that manifold works. It looks interesting though.
Old Sep 17, 2007 | 08:40 PM
ef8_eg6's Avatar
Default Re: (soulpwr)
yeah only the dyno will tell..should make the power im looking for though. im not asking for much
Old Sep 18, 2007 | 02:24 AM
TypeSLO's Avatar
i've seen a stock mani conversion like that a while ago. the "poor man's top mount". interested to see how it does.
Old Sep 18, 2007 | 03:14 AM
Topdawgg's Avatar
wheres the oil feed line, and why is the inlet blocked off
Old Sep 18, 2007 | 07:10 AM
ef8_eg6's Avatar
Default Re: (Topdawgg)
the feed line hasnt been taped yet..but you can still see it in the first pic..the inlet aint blocked off its facing down
Old Sep 18, 2007 | 09:31 AM
BlackCRX's Avatar
any pics of the manifold itself??
nice work so far man
Old Sep 18, 2007 | 11:57 AM
HiProfile's Avatar
Default Re: (BlackCRX)
Im thinking its just the light making the oil inlet hole/nipple hard to see. I want to do a dual-runner like that soon, I just wish I had a car that didn't come with AC. There's so much space when that ***** not in the way. Looks great.
I have a similar manifold - I used a LX manifold (4-1), put a ssauto WG on one elbow (recirculated), 3" DP, 50trim T3. With a stock exhaust/cat it made 160whp on 6psi. Not bad for a $9 manifold. I wanted more, but I need to replace the clutch this weekend. It was a treat to design since I kept all stock AC parts.
The best part is the money I saved went to raw materials and a 120CF argon tank so I can TIG a bunch of better manifolds.
Old Sep 18, 2007 | 09:35 PM
ef8_eg6's Avatar
i have no pic of the mani itself..but the car should be done in about 3 weeks so i will be posting pics of evrythings
Old Sep 22, 2007 | 09:00 AM
ef8_eg6's Avatar
Old Sep 24, 2007 | 03:32 PM
ef8_eg6's Avatar
hers the pic's ppl were asking for
Old Sep 24, 2007 | 04:41 PM
dreadcivicturbo's Avatar
Default Re: pic's of my set up (ef8_eg6)
i like it
Old Sep 24, 2007 | 04:52 PM
welfarepc's Avatar
your design looks like it will actually flow well. gj
Old Sep 24, 2007 | 05:05 PM
Turbo Dan's Avatar
does anyone else think that intercooler is quite a bit overkill for his engine mods and turbo size?
Old Sep 25, 2007 | 07:35 AM
ef8_eg6's Avatar
Default Re: pic's of my set up (dreadcivicturbo)
thanks yeah it flows hella good...and the inercooler hey the bigger the better...if i ever want to build y motot theres no need to get biggeer innercooler
