Help with b18b
ok I have a b18b ls motor I just got the ls transmission and my friend says that there is 2 shift linkages and I would have to order them from a crx sir? I dont know if that is true I just want to know what I have to do.
I have the mounts for it to fit into the rex I also have a ecu and wiring harness from a 94 integra my friend said I can use both the ecu and harness he said I will need a floor harness
I need the shift linkage for the cable ls transmission,
a few other little things (shifter bushings fenders shocks)
So what do I need to do to get this thing going if someone knows can they send me a direct link to what I will need
and where I can buy this shift linkage if it is true. They have a shop here in orlando fl that sells it for $120 my buddy said I just dont want to buy nothing that I dont need and wast my money. Thanks in advanced.
Use stock 90-93 shift linkage, and cut and weld to fit. If you don't have access or teh skillz, just buy pre-made or adjustable shift linkage.
If you want to use the ECU, you will need an obd0-obd1 jumper harness, or make your own.
Use your stock engine harness, extend/shorten/add any wires necessary. You can't actually a plug an integra engine harness into a civic chassis harness, so you must re-use the civic one.
As for the rest, all the odds and ends, there are a buttload of links in the FAQ.
Hoppa
Apr 26, 2006 06:29 PM
dsmarefaster
Apr 12, 2005 08:55 AM
