My First Ls/Vtec Build
Old Sep 17, 2007 | 11:27 AM
asnickdies's Avatar
Default My First Ls/Vtec Build
I'm getting away from boost for a while, and decided to build an all motor setup. This is actually my first one. Setup is as follows..
**COMMENTS, OPINIONS, & SUGGESTIONS WELCOME**
*STAY TUNED*
UPDATE!!! ( More Pics Up Tonight )
Its been about a month since I've posted any progress. So heres how it's coming along...
- Sold Victor X / Bought ITR Manifold
- Sold My Crome P28 ECU / Bought Hondata S200 w/ Socketed P28
- Motor Assembled ( Clearances Checked... Everything Is Perfect )
- Right On Time
BLOCK:
B18b1 LS Block
Shotpeen LS Rods
New OEM .25 OS JDM P30 Pistons
New OEM Piston Rings
Fresh Bore & Hone
Resurfaced ( .004 )
VAT. Blasted (Cleaning)
Resized Rods w/ ARP Rod Bolts
Micropolished Crank
New ACL Bearings
New OEM ITR Oil Pump
Balanced Bottom End
New OEM Seals And Gaskets
HEAD:
2000 B16 Head
Port & Polished
Milled ( .004 )
Ferrea Valves
Ferrea Valve Springs & Retainers
New OEM Valve Seals
Buddy Club IV Cams
AEM Adjustable Cam Gears
RC 310 Injectors
ITR Intake Manifold
Hondata Intake Manifold Gasket
*BUDDY CLUB IV CAMS*
TUNING:
The plan was to tune w/ Crome, but nobody tunes Crome around here.
So I switched to this...
*Hondata S200 w/ P28 ECU*
MISC:
*FULL-RACE LS/VTEC KIT*
*TYPE R WATER PUMP, TIMING BELT, & TENSIONER. OEM B18B HEADGASKET*
*OEM GASKET SET*
*GSR/ITR HEADSTUDS*
THE MOTOR IS GOING INTO A 92' SI HATCH
Modified by asnickdies at 4:48 PM 11/19/2007
Old Sep 17, 2007 | 11:47 AM
bambam's Avatar
I love your parts selection and what you've chosen to do with the bottom end to make it reliable. I can't wait to see what those cams will do on this motor. BC4's are still my favorite to this day. Piece of advice though...ditch the full-race dowel pins and grab a $20 set of GE ones off of ebay. The FR ones are extremely loose....unless they've corrected that problem already. Other than that, it's a great kit and I've never had any complaints with it, nor have my friends.
Old Sep 17, 2007 | 12:35 PM
American.Graffiti's Avatar
Default Re: (bambam)
That **** is going to be a beast, who are you gonna have tune it?
Old Sep 17, 2007 | 02:52 PM
4g hatch's Avatar
those cams are gonna rip. whats this motor gonna go in,hopefully a crx i always thought that manifold would be to big for all motor but ive seen some b20-vtecs make great #'s with it. im in for the final #'s
Old Sep 17, 2007 | 03:50 PM
mx621's Avatar
Default Re: (4g hatch)
hey that build looks like mine, lol
Old Sep 17, 2007 | 03:55 PM
bambam's Avatar
Default Re: (mx621)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mx621 &raquo;</TD></TR><TR><TD CLASS="quote">hey that build looks like mine, lol </TD></TR></TABLE>
Did you use my guide?
Old Sep 17, 2007 | 03:56 PM
AccordSleeperZzZ's Avatar
sick build, dude.
lookin' good.
Old Sep 17, 2007 | 06:43 PM
401B18TEG's Avatar
look like a powerful setup. post some number if you have time.
Old Sep 17, 2007 | 10:13 PM
asnickdies's Avatar
Default Re: (401B18TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambam &raquo;</TD></TR><TR><TD CLASS="quote">I love your parts selection and what you've chosen to do with the bottom end to make it reliable. I can't wait to see what those cams will do on this motor. BC4's are still my favorite to this day. Piece of advice though...ditch the full-race dowel pins and grab a $20 set of GE ones off of ebay. The FR ones are extremely loose....unless they've corrected that problem already. Other than that, it's a great kit and I've never had any complaints with it, nor have my friends.</TD></TR></TABLE>
Thanks, and for reliability. I've also heard the full-race dowel pins wobble. Golden Eagle is the plan.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by American.Graffiti &raquo;</TD></TR><TR><TD CLASS="quote">That **** is going to be a beast, who are you gonna have tune it?</TD></TR></TABLE>
Thanks man I hope so. I'll probably take it to T1 Race Development
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g hatch &raquo;</TD></TR><TR><TD CLASS="quote">those cams are gonna rip. whats this motor gonna go in,hopefully a crx i always thought that manifold would be to big for all motor but ive seen some b20-vtecs make great #'s with it. im in for the final #'s </TD></TR></TABLE>
Its going into a 92' Si hatch. I've thought about switching the Victor X for an ITR. Maybe I'll just try them both out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccordSleeperZzZ &raquo;</TD></TR><TR><TD CLASS="quote">sick build, dude.
lookin' good. </TD></TR></TABLE>
Thank You.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 401B18TEG &raquo;</TD></TR><TR><TD CLASS="quote">look like a powerful setup. post some number if you have time.</TD></TR></TABLE>
Thanks. I should hopefully have some numbers by the end of this month
Old Sep 18, 2007 | 09:46 AM
asnickdies's Avatar
Default Re: (asnickdies)
Hey BamBam, you said Buddy Club IVs were your favorite cam? So im guessing you've used them.. Would you consider them a mild or wild cam, and how did they idle for you?
Old Sep 18, 2007 | 10:36 AM
401B18TEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asnickdies &raquo;</TD></TR><TR><TD CLASS="quote">Hey BamBam, you said Buddy Club IVs were your favorite cam? So im guessing you've used them.. Would you consider them a mild or wild cam, and how did they idle for you? </TD></TR></TABLE>
I was going to get the BC3 but the BC4 came out and want to know about this. Do i need to upgrade my spring and retainer and PNP to run these cams?
Old Sep 18, 2007 | 11:31 AM
bambam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asnickdies &raquo;</TD></TR><TR><TD CLASS="quote">Hey BamBam, you said Buddy Club IVs were your favorite cam? So im guessing you've used them.. Would you consider them a mild or wild cam, and how did they idle for you? </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 401B18TEG &raquo;</TD></TR><TR><TD CLASS="quote">
I have run them...and continue to run them. I can't compare them to much any other high end cam...but after tuning, the cams just kept pulling until I let off the gas. Most other dyno graphs on here backup the butt dyno. I tuned my AFR's down perfect and degreed the cams so idle was near 1000 RPM's w/ little to no lumpy exhaust tone.
I was going to get the BC3 but the BC4 came out and want to know about this. Do i need to upgrade my spring and retainer and PNP to run these cams?</TD></TR></TABLE>
Springs/retainers: Yes.
PNP: No. But more airflow/velocity=more power (assuming you have the compression to support it)
Old Sep 18, 2007 | 11:39 AM
401B18TEG's Avatar
ls wit p30.
Old Sep 18, 2007 | 12:26 PM
methos713's Avatar
nice, keep us updated
Old Sep 18, 2007 | 12:56 PM
HondaBurger's Avatar
Default Re: My First Ls/Vtec Build (asnickdies)
that block is fresh!! lol That definately looks like a reliable and definately a powerful build. definately post the hp and tq numbers when its all said and done. Im building an ls vtec as well and throwing it in my 95 cx hatch as well. Hatchbacks and crx's all the way lol!
Old Sep 18, 2007 | 01:02 PM
kpowerdhatch's Avatar
I think you'd be better with the performer X compared to the victor X. have you seen mikeyspec's comparision?
Old Sep 18, 2007 | 02:15 PM
Chillinit's Avatar
Default Re: (kpowerdhatch)
Build list looks good. Good luck with it, those BC4's should give you a nice power band.
Old Sep 19, 2007 | 06:43 AM
asnickdies's Avatar
Default Re: (Chillinit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 &raquo;</TD></TR><TR><TD CLASS="quote">nice, keep us updated </TD></TR></TABLE>
Thanks man. Will do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaBurger &raquo;</TD></TR><TR><TD CLASS="quote">that block is fresh!! lol That definately looks like a reliable and definately a powerful build. definately post the hp and tq numbers when its all said and done. Im building an ls vtec as well and throwing it in my 95 cx hatch as well. Hatchbacks and crx's all the way lol!</TD></TR></TABLE>
Thanks. Stay tuned for dyno #'s, and good luck w/ your build. Eg Hatch's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpowerdhatch &raquo;</TD></TR><TR><TD CLASS="quote">I think you'd be better with the performer X compared to the victor X. have you seen mikeyspec's comparision?</TD></TR></TABLE>
Yeah I saw that thread. What a difference. I got the Victor X from a buddy for cheap. I haven't made up my mind on an intake manifold. It's between Victor X / Skunk2 / ITR, but the Victor X should be fine for now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit &raquo;</TD></TR><TR><TD CLASS="quote">Build list looks good. Good luck with it, those BC4's should give you a nice power band. </TD></TR></TABLE>
Thank you. Good midrange & top end is what I'm looking for.
Old Sep 19, 2007 | 11:14 AM
b20beast978's Avatar
looks like another great thread!
Old Sep 19, 2007 | 02:46 PM
EK Dave's Avatar
With that oem head gasket,will you be a little low on compression to get the most from the bcs4.I know you took some off the head but will you suffer a bit with out bigger compression?
it looks a very well done build,how much research have you done before you started it?
Old Sep 19, 2007 | 03:09 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: My First Ls/Vtec Build (EK Dave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK Dave &raquo;</TD></TR><TR><TD CLASS="quote">With that oem head gasket,will you be a little low on compression to get the most from the bcs4.</TD></TR></TABLE>
he definetly has enough compression for those cams
nice setup... but it is all going to be up to your bolt-ons to get the true potential out of that motor
Old Sep 19, 2007 | 03:18 PM
cartune network's Avatar
Default Re: My First Ls/Vtec Build (coptzer)
nice lookin build man. u should put some good power down with it. the more compression the better well atleast with those cams.
Old Sep 19, 2007 | 03:51 PM
bambam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK Dave &raquo;</TD></TR><TR><TD CLASS="quote">With that oem head gasket,will you be a little low on compression to get the most from the bcs4.I know you took some off the head but will you suffer a bit with out bigger compression?
it looks a very well done build,how much research have you done before you started it?</TD></TR></TABLE>
By my calculations, he's somewhere around 12:1. I think that's plenty.
Old Sep 19, 2007 | 07:34 PM
asnickdies's Avatar
Default Re: My First Ls/Vtec Build (bambam)
Hey guys thanks for all the replys. As far as compression goes, about 12:1 is what I figured out too. Another reason I chose the oem headgasket is to increase my piston to valve clearances. I'm paranoid. I totaly agree that bolt-ons make a huge difference.
I pick my head up from the machine shop tomorrow.
BUMP FOR MORE PICS
Old Sep 20, 2007 | 12:19 PM
asnickdies's Avatar
New pics of the head are up.. What do you guys think?
