wire harness
hey, ok i think i really fu*ked up.....i was drilling the hole in the firewall for my fog lights. and i wasnt really paying much attention
to what i was doing and i accidently drilled a hole through a cover and then through some of the wires that were behind this cover. The cover is located behind the clutch pedel, and has alot of wires in it...I think i am going to need a new wire harness...what do you guys think??...the speedo, right blinker dont work and the check engine light is on now.....help!
AJ
to what i was doing and i accidently drilled a hole through a cover and then through some of the wires that were behind this cover. The cover is located behind the clutch pedel, and has alot of wires in it...I think i am going to need a new wire harness...what do you guys think??...the speedo, right blinker dont work and the check engine light is on now.....help!AJ
james2475
Lighting
Aug 12, 2018 11:38 AM
