Selling my car!
1999 Honda Civic SiR
Engine:
- B16A2
- Jdm ITR valve springs, retainers
- Jdm CTR camshafts
- Jdm ITR intake manifold w/ throttle body
- Hondata intake manifold gasket
- Apexi Power intake chamber w/ Apexi intake filter
- Mugen 2 ply head gasket
- Jdm Koyo half rad w/spoon fan switch, and thermostat
- Energy Suspension poly-motor mount inserts
- Jdm Vision header, Jdm CTR 2.5’ catalytic converter, custom 2.5’ B-pipe, Usdm Mugen twin loop axle back exhaust (all bolt on, no welding)
Engine Management:
- Chipped P28 obd1 ecu w/ jumper harness
- Apexi vafc vtec controller
Transmission:
- O.e.m 4.4 gearing
- Usdm ITR clutch disc
- Usdm ITR pressure plate
- Usdm ITR flywheel
- Jdm shift linkages w/ Energy Suspension shifter bushing kit
Suspension:
- O.e.m front upper strut bar
- O.e.m front lower sway bar
- Rear upper strut bar (generic)
- Rear lower tie bar (generic)
- O.e.m rear lower sway bar
- Endless/Zeal Function B6 Full coil-over assembly, spring rate front 14k rear spring rate rear 10k, 6 way dampening, compression/rebound adjustable
Tires/Wheels/Brakes:
- Advan A032R 205-50-15
- SSR Type C (limited edition white) 15x.6.5 42 offset
- O.e.m brake callipers, pads, rotors, brake lines
Cosmetics exterior/interior:
- Vis first edition carbon fiber hood, bought in 2000
- Honda S2000 side markers
- RS emblem
- Honda Access window visor kit
- O.e.m fog light kit
- O.e.m rear lower bumper skirt
- Spoon knockoff side mirrors
- Spoon valve cover and or Jdm ITR red valve cover
- Momo Course 320mm steering wheel w/ hub adapter
- 98 Integra front seats
- Jdm ITR shift boot
- J’s racing style shift ****
-O.e.m dual din radio block off plate
- Alpine head unit
- O.e.m passenger side air bag block off tray
Any questions? 294-5933
$ 15,500 o.b.o
Serious inquiries only!
Engine:
- B16A2
- Jdm CTR camshafts
Engine Management:
Transmission:
- O.e.m 4.4 gearing
- Usdm ITR flywheel
Suspension:
- RS emblem
- Alpine head unit
$ 15,500 o.b.o
MENACEteg
Feb 2, 2011 06:44 AM
spoon23_JDizM AkA SpOoN20
Mar 21, 2006 05:49 AM
Seedc2
Jun 3, 2003 11:57 AM
