What cd changer compatible with oem 98 civic ex changer?
Old Sep 16, 2007 | 07:43 PM
beef-cake's Avatar
Default What cd changer compatible with oem 98 civic ex changer?
Wondering if there are any aftermarket cd changers that can plug in with my 98 civic ex audio system.
Also, are there any other honda or acura cd changers that could work in my car?
Whenever I put the cd magazine in it automatically ejects the magazine.
Thanks.
Old Sep 17, 2007 | 05:11 AM
fcm's Avatar
fcm
Old Fart
Default Re: What cd changer compatible with oem 98 civic ex changer? (beef-cake)
Any Honda/Acura changer with 8pin din plug will work, It is an Alpine changer, [8pin din plug] but an adapter is needed for the Alpine changer. 94
Old Sep 17, 2007 | 09:11 AM
RepTheWest's Avatar
i have a alpine 6 disk changer that is for sale.....plugs into the honda/acura tape deck as long as you have the CD changer button on it. PM me if you are interested.
Old Sep 17, 2007 | 11:53 AM
fcm's Avatar
fcm
Old Fart
Default Re: What cd changer compatible with oem 98 civic ex changer? (RepTheWest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RepTheWest &raquo;</TD></TR><TR><TD CLASS="quote">i have a alpine 6 disk changer that is for sale.....plugs into the Honda/Acura tape deck as long as you have the CD changer button on it. PM me if you are interested.</TD></TR></TABLE> It will not plug in directly, you need an adapter.
Type of adapter will depend on HUs input, 8pin din or 14pin data. 94
Old Sep 17, 2007 | 06:42 PM
beef-cake's Avatar
Default Re: What cd changer compatible with oem 98 civic ex changer? (fcm)
Where can I get this adapter? Will any alpine cd changer work with these adapters? Where do I find this hus input that's 8 or 14pin?
Is it AI-NET or mini-bus type?
Modified by beef-cake at 7:55 PM 9/17/2007
Old Sep 17, 2007 | 06:53 PM
beef-cake's Avatar
Can i make this one work? CHA-S634
http://www.alpine-usa.com/US-e...-S634
Old Sep 17, 2007 | 07:01 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
if your headunit does not have the changer controls on the radio it will not control the changer. I know a older alpine will plug into a factory radio. I did one about 6 years ago. Not sure the model on it. But I bet they don't make it anymore so your going to have to buy a adapter
Old Sep 17, 2007 | 07:14 PM
beef-cake's Avatar
Default Re: What cd changer compatible with oem 98 civic ex changer? (wrx-killer-Sti-eater)
lol, yes mine does have a cd changer control, as I currently have a cd changer, that doesn't work.
Are you guys talking about the kca-130b adapter?
I just read on crutchfield.com that the factory keyless entry and alarm system is part of the radio and that I need to keep that plugged in to the car even if I install a in dash cd player. Anybody got a link on what needs to stay plugged in?
Modified by beef-cake at 8:34 PM 9/17/2007
Old Sep 18, 2007 | 11:36 AM
fcm's Avatar
fcm
Old Fart
The R/F section is built in, unless you *** an aftermarket alarm you will have to leave the OEM HU plugged in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti-eater &raquo;</TD></TR><TR><TD CLASS="quote"> I know an older alpine will plug into a factory radio. I did one about 6 years ago. Not sure the model on it. But I bet they don't make it anymore so your going to have to buy a adapter</TD></TR></TABLE> Although you could "force" the alpine 8pin din plug into the Honda/Acura HUs 8pin din plug, [plugs are a little diff.] and the change would work, the left/right output will be out of phase, as signal return, [grounds] and left signal are reversed on the Honda/Acura HUs. 94
Modified by fcm at 6:35 AM 9/20/2007
Modified by fcm at 6:36 AM 9/20/2007
Old Sep 19, 2007 | 07:54 PM
beef-cake's Avatar
So to avoid the left right phasing being off, what alpine decks will work? Or will only the oem honda 6 disc changers work?
Old Sep 20, 2007 | 05:34 AM
fcm's Avatar
fcm
Old Fart
Without an adapter only the OEM changer will work properly.
If your stock HU has the 8pin changer din plug on the back then it is a very simple adapter, [Alpine style female 8pin din plug on one end and OEM Honda 8pin din plug on the other end, and the older style Alpine changer will work.
You can also just buy the Honda style 8pin din plug at Radio Shack, this is a Honda style 8pin din plug... http://cgi.ebay.com/8-Pin-DIN-...wItem [the Alpine 8pin din plug is a 270 degree plug] cut the Alpine plug off the cord and install the Honda style plug, reversing the left signal and and signal ground pin positions.
If however your HU has the 14pin changer plug on the back, the adapter is more complicated, [more expensive] but then you can get one for probably just about any brand of changer.
So the first thing to do is pull the HU and see which changer plug you have. 94
98cdmej6
Audio / Security / Video
Sep 4, 2011 07:58 AM
kwahamot
Jun 25, 2010 10:00 PM
ITR EG
Sep 23, 2004 11:56 AM
eg686
Mar 18, 2004 08:42 PM
cxSHOE
Mar 3, 2004 09:06 AM
