what rods??
im rebuilding my b18b bottom end and id like higher compression. so using cspeedracing.com compression calculator i was thinking about going with this set up but it raises several other questions.
heres the compression calculator link
http://www.c-speedracing.com/h...c.php
speaking of compression calculator does anyone know of one that includes rod length?
set up
b18b block bored .25 over
b18b head
b16a (p30 jdm) pistons 81.25
oem 3 layer head gasket
stock piston to deck height
now according to the calculator that leaves me at about 11.01compression
questions.
1. is that with stock b18b rods (137mm)?????????
2. where do you get jdm b16a (p30) pistons .25 over?
thanks
set up
b18b head
questions.
thanks
okay so nevermind the p30 pistons, i can use usdm pr3 pistons and a 2 layer head gasket and have 11.13 compression.
however i still dont know which rods im suposed to be using. a little help would be greatly appreciated
wushubrian
25
Aug 31, 2006 01:52 PM
SOHCD16y8
Oct 4, 2005 06:03 PM
Slopoke
Oct 4, 2001 09:27 PM
