CrookeD aSS IntegrA - NeIDEA'S?
Old Sep 16, 2007 | 05:01 PM
Mfoehrkolb's Avatar
Default CrookeD *** IntegrA - NeIDEA'S?
Been bothering me for a while now, my back seat doesn't line up with the other. In the pictures i have it unlatched and even with the other seat, and you can see how much of a gap there really is b4 it would latch. Also, my rear hatch is close gapped on the right side, and on the left side its gapped pretty large.
My friend says "Its not the frame, nothing is bent, its just that it is a 94."
I think shomething is bent, anyone have problems like this b4?
GAPPED SEAT
GAPPED HATCH
Old Sep 16, 2007 | 05:42 PM
itsmedavid's Avatar
Default Re: CrookeD *** IntegrA - NeIDEA'S? (Mfoehrkolb)
The problem is not with the latch its in the middle where the other end of the seats goes. The seat is not completely in thats why it has that gap. I can make it flush again but after a while it becomes off track and becomes gapped again. Mines is a 94 LS i want to know how to fix the problem permanently.
Modified by itsmedavid at 7:45 PM 9/16/2007
Old Sep 16, 2007 | 06:06 PM
Mfoehrkolb's Avatar
idkw hat that picture is, and can you tell me what you did to fix yorus.
Old Sep 16, 2007 | 06:17 PM
LordAphotic's Avatar
if that car was T-boned before and the seats are installed properly but still dont line up ur gona have to make some brakets bro to make things line up right. Or fix the body so that its right..
IF the seats are installed right then i recomend taking out the panels so u can see where exactly its not so straight. and take measurements of both sides to compare how far off it is....
based on that information u can make brackets to compesate for that... if u can weld then it wiill be pretty good... if not then just use a couple self tapping screws and it should hold fine for a long while.
Old Sep 16, 2007 | 06:26 PM
Mfoehrkolb's Avatar
car was never in a accident, axcept for when i went off a speed bump @ 60 adn bent my rad support up. but nothing too serious to the rear end.
Old Sep 16, 2007 | 06:41 PM
brownpride016's Avatar
i have the same problem it irritates me soo much i had it in my 93 eg6, in my 97 dc4, and i have it in my 96 dc2 and im still clueless they all have never been in any accidents and what not... everything on all of em are straight except the back seat
Old Sep 16, 2007 | 07:17 PM
mcc361's Avatar
75.16.118.214
i had the exact same problem with my 94 ls and when it rained all the water stood in a puddle! the seats wouldnt line up either!! never figured out what it was
Old Sep 16, 2007 | 07:24 PM
Mfoehrkolb's Avatar
Default Re: (brownpride016)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brownpride016 &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem it irritates me soo much i had it in my 93 eg6, in my 97 dc4, and i have it in my 96 dc2 and im still clueless they all have never been in any accidents and what not... everything on all of em are straight except the back seat</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcc361 &raquo;</TD></TR><TR><TD CLASS="quote">i had the exact same problem with my 94 ls and when it rained all the water stood in a puddle! the seats wouldnt line up either!! never figured out what it was </TD></TR></TABLE>
--- SO LAME! Someone FiX this!
Old Sep 16, 2007 | 08:14 PM
are you guys sure u have them installed properly?
do u have the little black C clips in place?
are the metal rods inserted into the metal hole in the side of the seat?
Old Sep 16, 2007 | 08:19 PM
Mfoehrkolb's Avatar
i have never taken these out of the car. so i would imagine everything is still in place.
Old Sep 16, 2007 | 08:41 PM
itsmedavid's Avatar
Default Re: (LordAphotic)
Yes i did have the c clips installed.
These are the clips
Old Sep 16, 2007 | 08:51 PM
thats strange... did u own the car ur entire life?
when did u notice that gap in the hatch? was it always there or did u notice it was different one day?
iduno... just seems strange to me... somethings damaged or not installed right..
the ONLY way ur goign to get to the bottom of this is to strip the rear interior and seats to check things out.
Old Sep 16, 2007 | 09:51 PM
Mfoehrkolb's Avatar
i had it for almost a half year now, but i bought it off my friend and he had it for a long tmie. its a 3 owner 94. he said he replaced the carpet, i just spoke to him a bit a ago. so maybe its just mounted weird.
Old Sep 16, 2007 | 10:37 PM
gsrob's Avatar
That's wierd, my 94 Integra isn't like that. I would double check that you have those black plastic c clamp things in both corners of the seat. They have a little tab that works as a handle so you will know it's them if they are there.
Old Sep 16, 2007 | 11:00 PM
GIVEN that the car is physically fine... the problem will be that its not properly installed...
Theres plastic parts that the rods insert too.. and over time they break and then the seats will have enough play to let them move out of place.....
but u seem sure that they are installed right... though i think they arent.... if they are then the cars been wrecked.
Old Sep 17, 2007 | 04:56 AM
g0tgot's Avatar
the hatch might have been taken off on the past, or normal wear and tear, you can adjust that at the hinge......as far as the seats.....posible structure damage in the past and/or frame dmage from the past, you might want to get that checked out mang...
Old Sep 17, 2007 | 05:15 AM
Mfoehrkolb's Avatar
ima check the seat this weekened when im not lazy, and how do i adjust the hatch? -- the hatch gap and this seat gap **** me off.
Kidnkorner
Mar 8, 2010 04:26 PM
urquidezj
Jul 1, 2007 04:55 PM
white90crxhf
Jan 12, 2006 07:19 PM
MiKeAhOwSkI
Jan 13, 2005 08:51 AM
Rookie SPL
Aug 29, 2002 02:01 AM
