Suspension & Brakes Theory, alignment, spring rates....
koni yellow adjustment?
Old Sep 16, 2007 | 01:56 PM
92civeg's Avatar
Default koni yellow adjustment?
ok i have this set of koni yellows, and i knew about the adjustment at the top of the strut with the tool provided with them, but i was looking a the directions today and saw these pictures that show the actual "shaft" being turned? is this a way to get more adjustment or what?
heres some pictures
Old Sep 16, 2007 | 03:21 PM
mullet eater's Avatar
Default Re: koni yellow adjustment? (92civeg)
bump!
Old Sep 16, 2007 | 04:28 PM
nonsense's Avatar
No those are the instructions for internally adjustable shocks. They Yellows you have a re externally adjustable
Old Sep 17, 2007 | 05:30 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Those instructions show the adjustment procedure for the Koni red shocks. Do you also have a sheet showing the **** placed on top, or do you only have those? They may have put the wrong instructions in the box. I can't remember if they have instructions for both types of shocks in the same booklet or what.
Old Sep 17, 2007 | 05:37 AM
Targa250R's Avatar
be professional
As mentioned, those are the instructions to set the internally-adjustable Koni 8040-Specials ("reds") and some older 8041-Sports ("yellows"). I don't believe that Koni is making the internally adjustable 8041-Sports any longer.
If you have an adjuster at the end of the shaft that is turned with the plastic **** tool, then your dampers are externally adjustable.
Old Sep 17, 2007 | 11:21 AM
be.twenty's Avatar
strangely, my yellows came with those instructions also - of course it has been about 3 years since.. but still
Old Sep 17, 2007 | 04:46 PM
92civeg's Avatar
Default Re: (be.twenty)
cool thanks
Old Apr 27, 2008 | 12:52 PM
wlee112's Avatar
Default Re: (92civeg)
so externally adjustable koni yellows are the ones that i can simply pop my hood and trunk to adjust?
Old Apr 27, 2008 | 01:11 PM
BinMop's Avatar
Default Re: (wlee112)
yupp
Old Apr 27, 2008 | 03:37 PM
wlee112's Avatar
Default Re: (BinMop)
on the externally adjustable ones are the fronts and backs adjusted the same? why do i keep thinking that you have to jack the car up to adjust the rear struts?
Old Apr 27, 2008 | 04:11 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wlee112 &raquo;</TD></TR><TR><TD CLASS="quote">on the externally adjustable ones are the fronts and backs adjusted the same?</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">why do i keep thinking that you have to jack the car up to adjust the rear struts?</TD></TR></TABLE>
You don't.
Some KYB AGX rears (like those for '96-00 Civics) have an adjuster on the side at the bottom of the damper body which may require jacking to access, but no Konis are adjusted this way.
integerkgsr
Feb 21, 2004 10:52 AM
bearboy80
May 22, 2003 06:06 AM
VTEC-DA
Dec 28, 2002 10:41 PM
