what to do w/ the gas tank vent line????? help
* B A N N E D *
i'm doing a wire tuck and its in the way. search but found nothing good or safe
i removed the charcoal cannister,and just left the vent line hanging off the end of the hard line that comes into the engine bay.at my next track day,i was having fuel coming out of it under hard braking.as a temporary fix,i ended up extending the rubber line by about a foot,and running it up to the fuel filter area so that gravity would help keep the raw fuel in there.
of course,that would go against the point of a wire tuck...i honestly don't know.why did you post this here?are you tracking the car too?i'd post on one of the several wire tuck threads to see what other people have done if you're only worried about cosmetics.i guess you could possibly use a vented gas cap,and just cap off the vent line at the tank.not sure if you'd get gas coming out of the cap vent under hard cornering or not-the cap is up pretty high in relation to the tank.
chris
chris
* B A N N E D *
thx for the info and the first hand. but yes it's a track car. and i'm just about to start putting it back together. so thay will be one of the 1st things i'm gona need to get dont. and i know under hard braking the gas will come out. i just want is to be safe and very fonctional. and yes i did post in there also. but alot of ppl in this other forums have dont this so i figered i'd post here too
* B A N N E D *
i think i got the fix for what i need. tell me what you think. i was thinkin about buying a ebay breather tank. drillin a hold in the bottem and tapping it for a fitting and attach the gas vent line to it. then drilling a bigger hole at the top for a filter. and maybe baful it w/ some steal wool.
where will you mount this at?if in the engine bay,why not just retain the very well designed OEM charcoal canister?the purpose of the wire tuck is to clean up the engine bay-but you'll just be replacing one canister with another.if you must get rid of the stock canister,i think that simply having the vent line high enough up that it doesn't overflow raw fuel,and probably have the end turned down or have a breather cap on it so it doesn't get dirt into it will be more than enough.the whole catch can/breather setup is overkill IMO.
Chris
Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by essex »</TD></TR><TR><TD CLASS="quote">What happens if you roll over? Does it just pour out?</TD></TR></TABLE>
basically
a good reason to keep the above mentioned,well designed OEM part.i don't think you'd get a very substantial amount of fuel coming out though-the line is small,the fuel has to travel all the way to the front of the car,and i have the end of the hose plugged with a stopper that i drilled a small(about 1/32")hole in....
chris
basically
chris
* B A N N E D *
i'd mount it to the fire wall under or next to the brock booster. and i really didn't want keep the evap system. i have a breather tank for my motor. it's boosted.soooo i'm workin with what i got
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooledhonda »</TD></TR><TR><TD CLASS="quote">nope it's got to be both ways. under hard braking gas will somwtimes come they the vent line</TD></TR></TABLE>
not to be an ******* but can you please retype that statement so that it makes sense?
* B A N N E D *
THANK YOU!
someone that knows what i'm talking about. i think it's the safest way of going about it. after some hard braking the can might full up a lil bit and will "hopfuly" drain back into the tank. does this seem to be a good idea to others? lol maybe i'll start a new trend
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooledhonda »</TD></TR><TR><TD CLASS="quote">no you can not put a check valve cus the air flow needs to go both ways. get in a better mood
dude, i was in a great mood it's just that i couldn't figure out what you were saying, and valued your reply.
no harshness intended.
</TD></TR></TABLE>dude, i was in a great mood it's just that i couldn't figure out what you were saying, and valued your reply.
some diggin right here lol. Really the only response google could find on this subject. I was told by someone to vent it out the back and higher than the tank. Think if it vents back maybe the gas wont push forward since the line is behind? What to do?
This is what I have on my race car.
http://www.jegs.com/i/JAZ+Products/5...25-01/10002/-1
and this
http://www.jegs.com/i/JEGS-Performan...51148/10002/-1
Mounted off the drivers side shock tower.
You can even vent your valve cover into it if you want to.
How? drill a hole into it smaller than your line at the top of the unit and push that sucker in to the bottom.
Unless your looking for something more "engine tucky"
There are "cleaner" options
You are on the right track.
and this
Yeah I want to eliminate the line running to the front all together. Without the charcoal canister up front there really is no need to have a vent go to the front of the car. I'm thinking maybe I can run the vent up to where the fuel door is. That would be higher than the engine bay and it would be more towards the rear and completely out of the way of the exhaust and other stuff.
i feel odd replying to an old thread but jdm style is to vent it directly to the TB. the jdm itr TB and probably others have a nipple for just this reason
well I tore out my fuel line and vent line today. Put in the new -6AN braided line for the fuel (original line had a kink causing fuel cut). The gas tank vent I didnt get to but no gas was coming out of it. I just left a piece of hose turned down towards the ground on it as a temporary solution (until tomorrow). I am going to run it up as high as I can towards the fuel door.
