wiper arm speed...
Old Jun 17, 2002 | 06:42 AM
crx(gator)'s Avatar
Default wiper arm speed...
ok my wiper speed is slowwwww...is there a way i can fix it, or do i have to buy a new motor?
Old Jun 17, 2002 | 07:20 AM
89 CRX SI's Avatar
Default Re: wiper arm speed... (crxgator)
are they both slow cause they run off different motors
Things you can check:
relay:
wires to motor
the actual plug on motor and see if it poped out or is corroded
batt voltage to plug should be ~12 V AC j/k DC
if thats all good unplug motor and try on someone elses batt. if it works prob your bat cant supply the amps needed for proper opperation.....
good luck
pscott3
Oct 9, 2014 09:20 AM
ZzZCivicZzZ
Mar 29, 2007 08:30 AM
GBRacing
Aug 3, 2006 10:00 AM
BeeResp0nsible
Feb 17, 2003 11:52 PM
