Header Clearance in an EF
Old Sep 16, 2007 | 10:07 AM
TheSauceSpot's Avatar
Default Header Clearance in an EF
running a b18c with a full race traction bar and 1/2 rad. in a 91 civic h/b.... what header will clear? not sit too low... cuz the car sits pretty low? whats the best header out there?
Old Sep 16, 2007 | 10:33 AM
FastAsleep's Avatar
Default Re: Header Clearance in an EF (HOTSAUCE01)
what are you looking to spend?
Old Sep 16, 2007 | 10:50 AM
Default Re: Header Clearance in an EF (FastAsleep)
money isnt an issue... well it is... but i plan on buying everything once... so whatever is best is what im buying.
Old Sep 16, 2007 | 12:20 PM
jdmboyef9's Avatar
Well if clearence is an issue then your going to be looking at getting a 4-2-1 header. If you go 4-1 you will smash the bottom 2 primaries and then be out $400-$900 You may also want to consider raising it back up because you will likely end up smashing your oil pan on that motor (happened to me twice in one summer and it doesn't matter how carefull of a driver you are)
gerard92692
Oct 22, 2013 07:39 AM
SolAssassin
22
Jul 21, 2009 03:52 PM
athoughts
23
May 3, 2006 02:59 PM
EG_93Civic
Feb 3, 2003 05:44 PM
Rydaddy
Oct 28, 2002 09:21 AM
